Old 09-03-2004, 05:39 PM   #1
tommygfunk
tommy . master of madness
tommygfunk's Avatar
my bent cab revisited
After beating, pushing, twisting and some tremendous heat terry [my bud] and I have my cab closer to straight. The driver’s side door shuts straight and clean, but the passenger side is still tweeked. If I line up the roof line and door top the door has a hell of a gap at the rocker. It I line up the hinges the door overlaps the b pillar and has a ¾” gap at the roof. But if I line up the body lines the hinges WILL NOT BOLT. I may need to redrill or worse wield the hinges. I have had to cut away some if the a pillar to compensate for all this. But I hope when it’s done it wasn’t all for not. But as a back up I am still looking for cabs. So keep me in mind. I’m short of funds because all this so a few hundred is all I can go.
The master of all I see in the never-ending madness that is my life.
1967 C10 frame off project [the wife's wedding present] "Lacey"
“Only a man so smart can act so stupid!â€
Tommy G. Funk
tommygfunk is offline   Reply With Quote
Old 09-04-2004, 12:19 AM   #2
hotrodtroy
hotrodtroy's Avatar
I feel your pain
I feel your pain, mine was rolled (by the p o) and needs to be straightened. I will be doing my best to straighten it until I can get a new one. Good luck with it.
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
