Old 09-04-2004, 12:37 AM   #1
flip66
flip66's Avatar
Drive shaft problems
I have a TH400 trans and am putting a one piece Drive shaft in it the shaft was sliding of the trans fine now all of the sudden I can not get it to slid on any Ideals what it might be. I can see where the yoke ( I think that is what its called) has a notch in it but I can see where it lines up with the shaft coming out the trans.
flip66 is offline   Reply With Quote
Old 09-04-2004, 03:02 AM   #2
1972C10
1972C10's Avatar
sometimes they are a pita Make sure its clean inside the yoke could have some rust or trash unless it was the same yoke.
I was under the impression that to run a one piece on a longbed you had to submodify the cross member for additional clearence.
1972C10 is offline   Reply With Quote
Old 09-04-2004, 06:10 PM   #3
flip66
flip66's Avatar
its the same one that was on it. It slide on and off just fine then I could not slide it on any more.
I thought I would have to cut the cross member too but it looks like I all I have to is remove the bearing mount, which has already been modified so I just have to unbolt it.
Old 09-04-2004, 08:14 PM   #4
SCOTI
SCOTI's Avatar
Have you tried lubing the splines w/trans fluid? Sounds like you've got a burr somewhere.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-04-2004, 09:10 PM   #5
gonebad2
Merciless Butcher
gonebad2's Avatar
Try getting someone under the truck to help you. The helper can hold the rear of the driveline and try to keep it level with the output shaft on the tranny while you slide the yoke into the tranny.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 09-05-2004, 01:32 AM   #6
flip66
flip66's Avatar
thanks for the help, it was a burr. for all of you that want a one piece drive shaft on your long bed have it made I got mine in and all I had to do was remove the carrier bearing mount.
Old 09-11-2004, 08:53 PM   #7
bluec10
bluec10's Avatar
What kind of a drive shaft did you use?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
