09-04-2004, 06:16 PM | #1 |
So it wasn't my alternator AFTER ALL!
I was just out looking at the truck, and I noticed something..my Alternator pulley is WAY crooked! So THAT'S why it hasn't been charging right AND screaming sometimes. I know what the problem is...it's my belt. The one I got on there isn't short enough, so I'm gonna go get a ½" shorter and an 1" shorter. I shoulda figgered this out LONG ago.
(But then again, I AM semi-retarded) So, if you're having voltage problems at idle, you might wanna look into the belt. |
09-04-2004, 07:22 PM | #2 |
Stepsides RULE
i got an alternator ?, when i left my lights on and drained my battery the other day, i had a belt squealling like a mofo, im guessing it was because the alternator was working full tilt to recharge my battery? It has stopped since so i guessed thats what it was, am i correct?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
09-04-2004, 08:47 PM | #3 |
Professional Grade
Yeah, if you run your battery way down, she'll screech something nasty until the battery has charged up. Very hard on your alternator belt / alternator, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
09-04-2004, 09:59 PM | #4 |
Actually, it wasn't the belt, it was the brackets. For some reason, I can't align the alternator with the rest of the pullies. Guess I'll get those purdy "Correct-Align" brackets from Summit.
09-04-2004, 10:40 PM | #5 |
california fill
if theres any squeal, something aint right.. belts should be aligned properly and TIGHT. alternators and power steering belts should never squeal. Even at full lock, my PS is quiet except for a slight noise from the pump.
pc |
09-05-2004, 03:25 AM | #6 |
Right turn Clyde
I haven't seen a strait alternator setup on a single truck that I have ever seen yet. They are fine for the most part until you get some rpms going then the belt will fly off or break usually. From what I have noticed the alternators always set crooked. The side where the 9/16 long bolt is out to far and the top alternator bracket is back to far.
It looks strait but if you really look at it, its not strait.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
09-05-2004, 05:53 AM | #7 |
Wow, that's EXACTLY my problem MyLilBowTie! Hmm..so I guess I should just leave it then huh? But that damn squeal is ANNOYING.
09-05-2004, 08:33 AM | #8 |
...straiGHt..... ...just being a wise azz
09-05-2004, 11:16 AM | #9 |
Garage Queen Material
on my stock engine, the bottom bracket fit perfect. on my new 350, i had to use 2 washers to make it fit snug.
and my alternator lines up perfect maybe its the single serp. belt that it uses http://www.ocbaud.com/pictures/engine/350side2.jpg Last edited by ocbaud; 09-05-2004 at 11:19 AM. |
09-05-2004, 11:20 AM | #10 |
oh yeah, is it bad that i had a bad dream last night in that i was working on my truck and notcied my alt. belt was almost ripped apart in one area???
haha |
09-05-2004, 02:21 PM | #11 |
mines straight! but then again i have a serpentine belt sytem...
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
09-05-2004, 04:11 PM | #12 |
Right turn Clyde
If you can get a serpentine belt setup like Eric has those help a lot. There on the newer trucks 85?-86-87 Im thinking and where stock, need alternator pulley - water pump pulley - and crankshaft pulley. Its v-belt but just the alternator is serpentine. I plan to goto this setup after I work out a deal with a friend to get the whole setup
I have been through about 5 belts, and countless times it has flipped or jumped. Im very proficient in installing the alternator belt in about 60 seconds.
09-05-2004, 07:26 PM | #13 |
You get what you pay for
85 had V-belts. 86 had one of each. 87 had serpentine. I think. I know 85 had V-belts and the 86's I've seen had both.
Mike 1985 Chevy C-10 |
09-05-2004, 09:01 PM | #14 | |
Under construction!
My 87' had V-belts.
2001 Silverado bagged on 22's. *Sold* |
09-05-2004, 11:34 PM | #15 |
Workaholic
Mom's 87 R-10 has v-belts. . .
09-06-2004, 12:14 AM | #16 |
Well, OK, I was wrong on the 87 trucks. But I do know for sure the 87 van I have is a serpentine belt. The 87 I-cube van I used to have was serpentine. Wonder why pickups didn't change in 87??
09-06-2004, 04:56 AM | #17 |
Well, with the shorter belt on it. I made a few trips around town. Above 3000rpm it was making like a weird "buzzing" sound, but then it stopped. Now though, there's no "SQUEAK!" when I rev it up.
But, I am going to get the Correct-Align brackets from Summit for $60 this weekend when I go up there. |
