Old 09-06-2004, 08:23 PM   #1
Red68
Red68's Avatar
Rewired my 68 this weekend waiting out the hurricane
When I heard the hurricane was headed this way I decided to order a wiring kit so I could pass the time. Boy did it work, I completely rewired the entire truck from front to back with the "Painless" 18 circuit harness. It was fairly easy. The only problem I run into was after I tested the system with a battery charger and everything worked, I hooked it up to the battery and Nothin, the battery charger says the battery is fully charged, my multi-meter shows 10-12 volts but I can't even get the lights to come on. Anyone offer any suggestions? Thanks
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 09-06-2004, 09:07 PM   #2
Randy70C-10
Randy70C-10's Avatar
Check your ground wires, all of them. 99% of the time it's a bad ground. Painless kits are great, I just installed one in my wifes 70.
Randy70C-10 is offline   Reply With Quote
Old 09-07-2004, 04:33 AM   #3
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Wink Hope to see ya
Hey Red,
good to see a Central Florida trucker on the board. I have a shop/property down in Haines City. Wish I was around, I would gladly help you but, i'm in Kuwait until the end of the year. Hope to catch up to you when I return. Good luck.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-07-2004, 04:53 AM   #4
70-Chevy
-Chris
70-Chevy's Avatar
how much did that kit cost?
1970 Chevy C-10 P/U, Shortbed, Fleetside - 5/7 drop, 496, TH400, 12 bolt.
BUILD THREAD - http://67-72chevytrucks.com/vboard/s...d.php?t=404481
2012 F250 Super Duty P/U - intake, exhaust, tuner, 4" lift with 35's
2017 Chevy Suburban (Wifes Car)
- Fully Loaded & Stock
"Some people spend an entire lifetime wondering if they made a difference in the world. But, the Marines don't have that problem."
Ronald Reagan, President of the United States; 1985
70-Chevy is offline   Reply With Quote
Old 09-07-2004, 07:21 PM   #5
Red68
Red68's Avatar
I purchased it from Eastwoodcompany.com, there are alot of different vendors that sell the Painless products. It was $350 plus shipping.
Old 09-07-2004, 08:21 PM   #6
Sweet72
Sweet72's Avatar
Either that battery is toast even though the charger shows that it's charged or you cooked a fusibe link with the charger. Try your battery in another car just to be sure.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-07-2004, 09:46 PM   #7
chevytruckfan
chevytruckfan's Avatar
Cool, I am about an hour and a half south of you down 27. And my first classic truck was a 38 chevy 1/2 ton drove to Colorado to pick it up and as soon as I got home someone offered 2x what I paid for it so I had to let it go. Thats why I bought my 47 panel to restore.
chevytruckfan is offline   Reply With Quote
Old 09-07-2004, 11:55 PM   #8
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
I am installing that very harness right now. Will not be finished for a day or 2 so I do not have any suggestions to fix your problem. I do have additional questions about this though. May I post them on this thread?
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-08-2004, 12:18 AM   #9
Blue85
Oilfield Trash
Blue85's Avatar
Does the painless kit still use the factory style bulkhead connector at the firewall?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 09-08-2004, 12:41 AM   #10
chickenwing
Had to cut my firewall a bit. Template that came with was NOT to scale. Found that out after 1st hole was cut. Fuse block late model GM.
Old 09-08-2004, 12:58 AM   #11
gonebad2
Merciless Butcher
gonebad2's Avatar
Chickenwing, I ran into the same fuseblock problem when I installed my Painless harness. Other than that, installation was straightforward. At least I will know for next time.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 09-08-2004, 10:02 AM   #12
chickenwing
Gone bad, did you have an a/c truck?
