Old 09-07-2004, 12:02 AM   #1
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
Cool thinking about making my lower control arm pockets lower, is this a good idea?
I want to lower the front a bit more and was thinking about making the cup inside the lower control arm lower. Right now it is even with the buttom of it. Just wondering what is the most i should do? Or should i even do it at all, would it be safe having it lower then the bottom, or am i just asking for trouble? Anyone ever done this and had problems? I need all the input i can. Thanks.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
Old 09-07-2004, 11:02 AM   #2
SCOTI
SCOTI's Avatar
My old roomate had dropped control arms on his 65. The spring cup on one of them caught the lip of a city manhole cover in the ground & promptly stopped the truck . . .... after jamming the bottom of the bed into the cab, the bottom of the front fenders into the cab, & destroying the arm/that side of the frame.
Dropped spindles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-07-2004, 07:04 PM   #3
Shane
Shane's Avatar
I agree with Scoti. Anything hanging below the "scrub line" is a bad bad idea.
Shane is offline   Reply With Quote
Old 09-07-2004, 07:18 PM   #4
LONGHAIR
It can be done, but you don't get enough drop (Safely) for the work involved.
You could make a support going from the front edge of the lower control arm down to the extended cup to give it more of a "ramp" rather than the solid bang from the side of the lowered cup. I doubt if you could get more than 1.5"-2". If that's all you want it can be done......
LONGHAIR is offline   Reply With Quote
Old 09-09-2004, 05:57 PM   #5
grnddwn
belly dragger
grnddwn's Avatar
I ground through 2 sets of controlarms on my 80 blazer in 1.5 years so I wouldn't want the cups any lower
grnddwn is offline   Reply With Quote
