Old 09-13-2004, 11:12 PM   #1
flip66
flip66's Avatar
rearend ID #
can anyone tell me where to find rearend codes. i found 3896839 on the pass side and gm55 on the driver side.
flip66 is offline   Reply With Quote
Old 09-14-2004, 12:02 PM   #2
flip66
flip66's Avatar
ttt
Old 09-14-2004, 04:38 PM   #3
john
member #16
john's Avatar
Look on the pass side axle tube about six in. out from punkin. It is stamped on the top toward the front side. The stamping isn't very deep, so you need to wire brush real good. Thisa is for 12 bolt 1/2 ton. John
john is offline   Reply With Quote
Old 09-14-2004, 04:47 PM   #4
flip66
flip66's Avatar
If I can find can you decode it or tell me where too
Old 09-14-2004, 04:50 PM   #5
john
member #16
john's Avatar
Here you go. John
http://www.americanclassic.com/paint_test.asp
Old 09-14-2004, 05:11 PM   #6
flip66
flip66's Avatar
thanks
Old 09-14-2004, 05:35 PM   #7
john
member #16
john's Avatar
That decoder doesn't seem to work. Post number here for answer. John
Old 09-14-2004, 10:16 PM   #8
flip66
flip66's Avatar
ha0806w
Old 09-15-2004, 05:04 PM   #9
john
member #16
john's Avatar
I show 3.73:1 John
Old 09-15-2004, 05:11 PM   #10
flip66
flip66's Avatar
thanks, there is a web site were you can put in your rpm and tire size and it will give you gear ratio do you know where it is.
Old 09-15-2004, 05:25 PM   #11
john
member #16
john's Avatar
Here is one of many
http://www.angelfire.com/fl/procrastination/rear.html John
