If one were to convert to Autometer gauges and choose to use the electronic version speedometer vs. the mechanical one, does this eliminate the speedo cable to the tranny? If so, where and how does the speedometer read the speed? A sensor goes somewheres?
Mitch 1978 Chevrolet Silverado C 10 454 BB, TH400 |
ROCKET POWER!
It does eliminate the speedo cable. You would replace your tramsmission's speedometer drive gear with a magnetic pickup unit, or a VSS sensor and run the wires to your speedometer.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
You get what you pay for
![]() Join Date: Dec 1999
I don't think so. I think the cable is still used but the speedo has a built in vehicle speed sensor. I asked Autometer about this when I was installing my Pro Comp gauges. At the time they didn't have an electric speedo in Pro Comp's and was told I would need to use the electric Sport Comp if I wanted to use my cruise control. Hooks up the same way as a mechanical gauge.
Mike 1985 Chevy C-10 |
Stepsides RULE
yeah swerve man is correct. the cable still exists, but instead of the colored gear in the tranny its got a little dillio thingie, its on the 87 models i think. but don't take that as in stone.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
Nah get a full electric gauge .. On that Th-400 you should * be abel to use a vss off an 89 C1500 W/T With 305 And A Th375 Try that it
VEHICLE SPEED SENSOR for a 1989 CHEVROLET TRUCK C1500 1/2TON P/U 2WD WITH AUTOMATIC TRANSMISSION (Change) Normal Stock Special Order Not Available Item Part No. Warranty Core Value Unit Price Availability Store Web WELLS SU1090 3 MO $23.99 TO TEST->LOCATE TEST CHART "SU17" IN WELLS TEST MANUAL WELLS SU1411 3 MO $109.99 It didnt give me an option to put in Th375 So either the W/T Had it special and vatozone dont have the option in the computer Doubtfull.. Or the 700R-4 And Th-400./375 use the same Vss as the 700 So maybe any 700R4 VSS will work Just make sure to use the proper drive gear to retain correct reading. Althou i think most automter electric speedos have a recalbration mode. |
After market makes Vss senders that just hook onto the speedo cable Hookup on the trans. as well as some that still retain cable operation but have wires for Electric VSS as well.
on all of the factory eletric speedometers that i have seen it was a meatle gear on the output shaft with a magnent sensor and wires running out, no calbe, i've got one sitting around out of a 700R4
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
ROCKET POWER!
To put it shortly:
Factory electronic speedometers use a transmission mounted vehicle speed sensors or VSS's. No cables, never. No optical devices either. Factory mechanical speedometers use a cable. If there's an electronic cruise control it uses a speedometer mounted VSS. Aftermarket electronic speedometers may use: 1. A factory magnetic induction VSS on the transmission. 2. A conversion kit magnetic VSS that replaces the speedometer cable but is GEAR driven by the transmission output shaft 3. A conversion kit that retains the speedometer cable, the speedometer itself has a VSS output for cruise, abs etc. When using a magnetic VSS and electronic speedo there are no optional drive "gears" on the transmission. The VSS signal is fed to a buffer, modulated for the proper gearing and tire size and then fed to the speedometer, cruise control and ABS if equipped. If you change rear end gearing or tire size and want the speedo to read correctly you'll need to change that buffer (DRAC or Digital Ratio Adapter Controller is GM lingo for it) or modify the existing one. This is how GM did it, anyway. So the proper answer to the original question would be: It depends on whether or not you get a semi-electronic or full electronic speedometer. If the former, see swerve's answer. If the latter, see mine.
Thank you all for your respective answers.
