Old 09-23-2004, 04:42 AM   #1
ocbaud
Garage Queen Material
steering problems...
since i've changed my spindles from the 2.5" western chassis ones, to the 3" djm ones, the steering is a lot different.
there seems to be a lot more play in the wheel and the truck will "glide" to the right side while driving.
i didnt move the tie-rod ends or anything that would affect the steering. anyone know whats up with it?
ocbaud is offline   Reply With Quote
Old 09-23-2004, 05:29 AM   #2
BaggedC10
Under construction!
BaggedC10's Avatar
Did you have the front-end aligned after installing the new spindles?
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 09-23-2004, 05:31 AM   #3
ocbaud
no. i didnt know i had to for spindle changes
Old 09-23-2004, 07:43 AM   #4
TIMSPEED
TIMSPEED's Avatar
You shouldn't HAVE to, but it wouldn't be a bad idea to have it CHECKED. Strangely, my truck glides to the right a bit too, with the DJM spindles. (The guy at the tire shop, told me my tire was causing it though, called it "Radial Pull")
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-23-2004, 03:22 PM   #5
Greenlee
Greenlee's Avatar
It maybe a situation where the leverage of the 3" spindles is exagerating a problem that was already there, such as worn tie rod ends. That is what happens alot of times when people switch to bigger tires. The steering system is worn, but its not noticeable until you put on the bigger tires.
Greenlee is offline   Reply With Quote
Old 09-23-2004, 03:52 PM   #6
swervin ervin
You get what you pay for
swervin ervin's Avatar
Anytime you do any work at all on the front suspension, it's a must to realign the thing. What's the chance that the tierod mounting points on the spindle will be exactly in the same spot they were on the stock ones?
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-23-2004, 03:53 PM   #7
Izzy
Trucker.
Izzy's Avatar
I agree, you're still changing the geometry of the front end no matter if it's spindles or springs.
Izzy is offline   Reply With Quote
Old 09-23-2004, 04:46 PM   #8
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Ditto! You are still changing components, so it needs to be realigned.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 09-23-2004, 05:23 PM   #9
Greenlee
Greenlee's Avatar
It may need to be aligned, but that wouldn't cause him to have more play in the steering would it?
Old 09-23-2004, 11:44 PM   #10
cliffsta
Stepsides RULE
cliffsta's Avatar
So when i change my shocks in about a month, i need to take my truck to the allignment shop?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-23-2004, 11:51 PM   #11
RockHQ
ROCKET POWER!
RockHQ's Avatar
Of course not. You're not touching the suspension geometry.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
