Old 09-23-2004, 08:03 AM   #1
Jetmech727
Lowering my 70
I'm planning on lowering my 70 chevy. Most of the kits I have seen are set up for coil spring rear end. I have a leaf spring rear end. What is the best couse of action in this situation? I would like to go 4" and 3" does tha sound pretty standard for a drop? Where is the best place to purchase the kit? Thanks in advance for the input
Jetmech727 is offline   Reply With Quote
Old 09-23-2004, 11:07 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Early Classic Enterprises sell parts to lower leaf spring rear trucks.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-23-2004, 11:13 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A spring flip kit would get you a little more than what you are looking for, so de-arched springs is probably what you'd need. Although, I'm not sure if you could get 4 inches that way.
Old 09-23-2004, 11:21 AM   #4
Tx Firefighter
Early Classic 4 inch drop leaf springs part #02-6372-4LF
Go HERE for their webpage of them and type in the word "leaf" in the search box.
Old 09-23-2004, 12:15 PM   #5
Jetmech727
would lowering block be an option? 369.00 for 2 springs seems a bit salty. I don't mind spending the money if taht is what it takes, but I would like to know if blocks is a good alturnitive?
Old 09-23-2004, 01:26 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
You would have to "flip" the rearend to use a lowering block. And,... if you flip the rearend, you would drop the back at least 6 inches. (Lowering block would not be required) Also a frame notch might be required. Look at ECE's stuff. Springs and shackles.
Keith
Convert to disc brakes.
Old 09-23-2004, 01:46 PM   #7
crazy longhorn
Fabricate till you "puke"
You can flip the axle.....then take the spring hangers off the frame, & drop them down to raise the truck back up a tick My longhorn was done this way, & to my best guesstimation, its between 4-5" of drop. the leafs are a 4 stack(tossed the helper & 2 or 3 leafs on the bottom). those old 3/4 ton springs are still fairly stiff, & with only 2 3/4" clearance tween the rails & axle it never bottoms! i do reccomend a good set of slapper bars to handle the wheel hop on a leaf spring truck. Best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
