What exactly do I have to do?
I am still having some problems getting my 350 running. I think it either has to be the points ignition way out of whack or my valve timing is off. What do I have to do to set valve timing? Don't you just pull the timing cover off , put the #1 cylinder at top dead center, then make sure the dots are lined up? I have an aftermarket Crane Cam if it matters....
Thanks in advance, hope to get it running this weekend...
1972 C10 1972 C20 ![]() |
get someone to turn over the engine for you......
pull out number 1 plug....first in front on drivers side....... have them click it over till your finger blows out of plug hole.....clicking slowly till balancer is lined up with the tdc timing tab......both mark's alined hei......rotor should point to #1 cyl....vac. advance should be in middle of adjustment..... points....rotor should point to number 1 on cap....or 2 tower from left of hold down screw on cap..... if not ......repair....... just looked you got points....pull cap make sure cond.wire is hooked....points are good gap.@ .019 to start..... after that.....install old plug in a wire and ground....turn over to look for spark...... look down carb....rotate linkage....check that you see gas .... good luck.... |
#3 | |
Still drivin' a Rat Rod
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Thanks, but what about the valve timing?
like RAGEN said the first 2things to make sure of are gas and spark the valve timing really wouldn't be an issue unless it was improperly assembled or your timing chain broke or streached and skipped teeth
Glowing since 1978
Your asking about timing chain setup from what I'm reading. The crank get rotated to TDC. Then I would pull the drivers side valve cover to look at the #1 cylinder rocker arms. If they are both shut then your timing should be right. You can rotate the engine and watch the valve move through there normal motion to verify it's right. I did have a friend once who installed the cam timing gear 180 degrees out because it looked correct that way. From my quickly fading memory on big blocks the dots get lined up but I thought small blocks the crank dot comes to the top and the cam arrow is also on the top. I'm not sure about that because I haven't had a small block apart for a long time. I'm sure the guys who routinely rip apart engines will help out. In any case if you do what I said in the top part you'll find it is correct or wrong by the valve motion. If no marks existed this would be how you would set it up unless you were into the degreeing a cam thing.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in 71 Corvette Coupe 454 4 speed 69 Chevy C20 Custom Camper |
#7 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 09-26-2004 at 03:44 AM. |
Right turn Clyde
Are you thinking about valve lash?
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73 1992 Camaro RS 305 TBI |
Update:
I had the ignition timing off by 180 degrees, I think... I aligned the 0 degree mark on the timing tab with the mark on the balancer, pulled out the #1 plug to make sure that it is at top dead center, and looked at the rotor. It was pointing the opposite direction than what it should have been. I pulled the distributer out and dropped it back in the right way. I tried starting it, and I get nothing. The motor turns over, and every second revolution gas sprays everywhere out the top of the carb. Kind of like a valve is open and all the compression is going out of the intake, shooting gas out through the air cleaner. Another thing is the points distributer. How close do the points have to be set for it to fire? Will it still run if they are way off? I don't think that they are set anywhere near where they need to be. I'm not working on an old junkyard motor here, everything is new. The whole bottom end was redone (bearings, turned crank, Crane cam, Cloyes double roller, hypereutectic pistons, moly rings, bored .030 over). I have heads that worked on the last engine they were on 6 months ago. The intake is a Edelbrock Performer series. The carb is new also, Edelbrock Performer. All plugs and wires, coil, points, cap, rotor are all new, all Fel-Pro gaskets were used. Like I said, all I am getting is just gas shooting up throught the carb and an occasional backfire or firing. This is really frustrating after all the time and money put into it...there isn't anything else to buy for it that could be worn out!
When the timing marks are lined up between the crank gear and cam gear for chain installation, it's firing on # 6 at that point.
1971 C10 swb stepside 350/700R4/3.73posi (retired as of 4/22/03) 1998 S10 short bed 2002 S10 Blazer 1942 Oldsmobile 1958 Massey Harris Pony 1951 Wife Killingworth, Connecticut May those who love us, love us, any of those who do not love us, may God turn their hearts. And if God is unable to turn their hearts, may he turn their ankles so we may know them by their limping. A man who works with his hands is a laborer; a man who works with his hands and his brain is a craftsman; but a man who works with his hands and his brain and his heart is an artist. |
I normally set points at about a matchbook cover. When you pull it up on #1tdc, make sure it is on compression, not exhaust. then set in the dist. Also, are the plug wires on the cap right? I have seen people have the right firing order, but wrong direction of rotation. Just somethings to toss out for you to check.
Dan |
Bring crank to TDC for #1 cyl. Timing marks on crank and cam gears should be one over the other Like ( : ). Check #1 cyl. valves to make sure they are both closed. Set dist. back in so rotor points to #1 cyl. At this time, you should be rough timed. Set points to 18-22 thou. Sound like from what you described, that right now you have your dist. 180 out of time? Try and start. When it does, turn dist. to run and let it warmup some. Connect your timing light and set timing. Not sure what that is for your application? Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
Thanks for the help, guys. I should get a chance to go over and work on it in a couple days. We'll see what happens. Thanks again...
