09-27-2004, 12:02 AM | #1 |
*Proud Member*
lets talk tires... WIDE tires :-)
I'm looking to get the rubber for the back of my stepside project and i'd like something nice and wide to wrap over my 15x10's for the rear. I've been looking at bridgestone & Hoosier's p325/50/15's b/c that'd be pretty wide, I assume. however, i've never seen the tires on a truck like ours, or the tires themselves... anyone have any experience w/ em? i'd rather NOT put hoosiers all the way 'round b/c of the money... any other brands/sizes that anyone can suggest ?
09-27-2004, 12:26 AM | #2 |
i've got 295/50/R15 on my 15X10s, foot patch is about 1 foot wide, i like them, they are about 26 inches tall.
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
09-27-2004, 09:50 PM | #3 |
Stepsides RULE
I've never understood tire dimensions. They are in CM right? Help me out:
275=heigth of tires from rim to outside ? 35=width of tread ? R 15= size of rim (i know that one) So that's like a 7 inch wide tire? (stock size tires )
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD 1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD 1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD 2009 Kawasaki KLX-250S too many mods for this signature 1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake Cardomain of the Accord |
09-27-2004, 10:08 PM | #4 |
ROCKET POWER!
no,
275= nominal width of contact pattern in millimetres 35=sidewall heigh, percentage of contact pattern width (0.35x275=96,25 millimetres in your example) R=radial ply 15=wheel diameter 92Z= 92 load range (Actual max. load is found in spec sheets in kilograms), Z=maximum sustained vehicle speed (found from spec sheets)
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
09-28-2004, 08:12 AM | #5 | |
275 - Width in millimeters of tire’s tread. 60 - Aspect Ratio - Percentage of tread width that equals the sidewall height. 15 - Rim diameter in inches. To calculate the dimensions use this formula (metric to decimal conversion) 275/25.4 = 10.8" tread width 10.8" x 60% = 6.48" sidewall height 6.48" x 2 + 15" = 27.96 total tire height
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
09-28-2004, 11:00 AM | #6 |
Check out this site for pretty much anything you need to know about tires....
http://www.tirerack.com/tires/tiretech/general/size.jsp Mike |
09-27-2004, 11:28 PM | #7 |
Stepsides RULE
so 275 = width of tire?
09-28-2004, 06:27 PM | #8 |
Stepsides RULE
So when i get a set of Eagle Series 054 15x8s i should get like 285 wide tires? Or would 275 still work? What sidewall percent thingie would i need to keep same tire height as to not affect speedo accuracy?
09-28-2004, 08:04 PM | #9 |
ROCKET POWER!
I would not mount tires any wider than 275mm on 8" (203.2mm) rims, generally speaking. However this is where sidewall height becomes an important factor, with a taller sidewall you can mount wider tires on narrower wheels, and vice versa. That's why you see people running eg. 33x12.50x15" tires on 15x8 wheels.
You'll need to be more specific. How wide a tire are you looking to run? What's under your truck now, and how off is your speedo now. Since you're going with 15" rims, your tires will need to have a taller sidewall than with bigger rims (17",18" etc) in order to not have a golf cart look, and not throw the speedo way off. A few popular sizes are 255/60/15, 275/60/15, 295/50/15 etc. When selecting a tire cost is always a factor too. Tire sizes that have seemingly close dimentions, eg. 255/55/15 and 255/60/15 can have a huge difference in cost and availability. With that in mind, sometimes it's a good idea to not be anal enough to care about 1/2" differences in tire diameter or tread widths. It can save you a lot of money.
09-29-2004, 12:19 AM | #10 |
Stepsides RULE
ahhh see that made more sense than anything i have read so far i have original size tires, and the factory wheels so speedo is pretty much dead on anyways. All i'm gonna want is basic tires for a 15x8 inch wheel. Nothing fancy, nothing crazy, just rubber for the wheels.
thanks
