Old 09-28-2004, 12:19 AM   #1
67chops
67chops's Avatar
Dual Exhaust ?'s
would adding 2" dual exhaust with glqass packs hurt the performance on a basicly stock engine? any good ideass on how to create some power and noise with the exhaust?
-Chops-
67chops is offline   Reply With Quote
Old 09-28-2004, 12:24 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That should increase performance. it would be even better if you add headers too.
Old 09-28-2004, 01:34 AM   #3
71Chevy4-speed
Speed Limit = Floorboard
71Chevy4-speed's Avatar
Actually stock hurts performance. 2 inch and glasspacks will be lots better than stock. What kind of motor is it? your sig says 67 truck so I'm guessing its a 327 at the most. I'd go with 2 1/4 with glasspacks. Headers would be a great add on too. Lots of flow. Most of the stock exhaust is like trying to breath through a coffee stir stick. Robs power and mileage.
1971 C20 350, 4-speed - Sold.
1985 K10 350, Built 700r4, Edel 1406, Performer intake, MSD Ign, Hooker Comps, Silverstars, Piaa drivers, LED tails, Toyo A/T 31's, Eaton Posi, the project.
"Build for torque, horsepower will follow"
71Chevy4-speed is offline   Reply With Quote
Old 09-28-2004, 01:39 AM   #4
dyingdeadman
dyingdeadman's Avatar
yeah, what they said.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 09-28-2004, 08:12 AM   #5
67chops
67chops's Avatar
excellent. thanks alot for the information. some one elsewhere said tht the dual exhaust would ruin my performance and i thought otherwise and you all helped answer that. and its actually a later 305 in my 67.
-Chops-
Old 09-28-2004, 08:37 AM   #6
Dean
Dean's Avatar
I guess you could argue that if you went really big on your exhaust it could lower the torque with a stock engine... A could set of duals is all you really need on that 305.
Dean is offline   Reply With Quote
Old 09-28-2004, 10:40 AM   #7
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Good point, Dean.
For the 305, I'd probably stay with 2" pipes to keep the flow up. Larger could detract from your low-end.
Glasspack noise output is a combination of diameter and length, so with a 2" diameter, you'll probably stay out of trouble with the sound police with anything 24" or longer.
If you have ambitions of a larger motor, especially bigger than 350, might want to go with the 2.25" pipes.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 09-29-2004, 12:22 AM   #8
71Chevy4-speed
Yeah with a 305 they are right about keeping the smaller pipe for torque, you could also invest in an h-pipe or x-pipe if you wanted that also helps torque by balancing out the tubes. Depends on what you want for sound, like they said bigger pipe rumbles more. Dean has a point about that you could argue that big exhaust will lower torque but stock is pathetic period.... its designed to be cheap, not powerful.
Old 09-29-2004, 12:27 AM   #9
rage'nrat638
rage'nrat638's Avatar
Thumbs up exhaust
you have got to have a double hump trans crossmember to get the clearence
under the truck.....
check my store....
http://cgi.msn.ebay.com/ebaymotors/w...e=STRK:MESE:IT
http://stores.ebay.com/RAGENRAT638S-...RUCKPARTS-MORE
rage'nrat638 is offline   Reply With Quote
Old 09-29-2004, 09:33 AM   #10
lock
Insert funny comment.
lock's Avatar
check my store....
Where do you run the pipes with that crossmember? Thru the holes near the frame rails?
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
