Holley power valve block off??
What are the disadvantages of running a power valve block off in a Holley 700DP?
Thanks, Nick |
If you block off the power valve you will need to install larger jets in the metering block you plugged the power valve on to make up the difference in fuel delivery. You may cause it to run way too rich though, you will have to experiment with different size jets to get the right mixture.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
Thats it? Just need to run bigger jets?
Why doesn't everyone just block them off then instead of jacking with these power valves? Thanks, Nick |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Holley made a running change some years back and starting putting power valve protectors in all of their carbs. Only the carbs that are some years old still have any real worries about backfiring blowing the power valve.
Ever since I bought my first Edelbrock carb, I've never personally wanted another Holley.
#5 | |
its all about the +6 inches
I agree with everything he said.
Senior Moment
![]() Join Date: Mar 2002
Funny how some people have better luck with different products. I have had 3 different Edelbrock carbs on 3 different trucks. 2 now have Holley’s and the 3rd will very soon. The Edelbrock just seemed to have more problems after some time. Personally I like the Holley 4777. Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 Last edited by 1970 CST Short Wide; 10-01-2004 at 11:58 AM. |
CCRider
Blocking off the power valve is a racing trick where the carb is only going to be wide open all the time. Will run like crap on the street, and what little gas mileage these trucks get will be down the toilet....get a new power valve
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
I agree I'd leave a power valve in the carb! You can get a kit to install in the base plate to protect the power valve!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Just get the proper power valve for your engine /application I have ran power valve blockoff plugs but like stated they are for RACE .
i block off the secondary PV...I tried last week blocking off the primary..ran good at the track..but off idle was crap..back to a primary PV
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
blood type; Retumbo
average rule of thumb depending on which metering block you have is to go up 10 in jets. but I suggets using PV on street as it introduces needed fuel when needed.
the lower # on PV the later (lower vac) it opens. install a PV saver kit like the ones from Mr. Gasket. even better yet if budget allows get a Demon. <has anyone here ever had a problem with Demons?>
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
