1991 driveline conversion
I have an 89 K3500 that I put the ORU kit in. Click on the link in my sig for some pics. I used a divorced 205, and a Gm Dana 60 axle. I wasn't too bad to do not having the right tools for the job. I have a 97 that Im gonna do the SAS in, soon as I get some time and money. Don't know how big of tire you gonna run, but if it's over 35s, and gonna take it wheeling, might want to hold for a D60, as that ten bolt ain't gonna hold up too well.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 4” SAS 1999 GMC Yukon 350/4L60 6" SAS |
save your money on the conversion kit. you can accomplish the same thing with a set of rear spring front hangers from a 73-87 2wd truck, use the rear shackles on your springs, then bolt the stock 78 front spring hanger to the bottom of your frame. i dont know if i would put a 350/203 in it, why not find a 208 or a passenger side drop 241 (208 will be easier to find, 241s were only available in 89-91 Blazers and Burbs IIRC) and bolt it to your 700R4. not only will it allow you to keep your OD, but will give you better all around gear ratios.
Ole Boy In arkansas did the Sas Swap with the brackets Previously mentioned It turned out really nice. Here are a few pics of his swap I havent gotten his permission but im sure he wont mind.
since you're looking into changing to leaf springs, you might want to look into 52" rear springs up front and crossover steering. is the parts truck a 1/2 or 3/4 ton? if so, you already have a set of 52" springs that will work. they will give you and extra 4-5" of lift.
thanks for the tips and pics.
did he use the original steering parts off of the 73-87 pickups?
I dont recall what he did for the steering . You might go to www.pirate4x4.com and search SAS swap you can find alot of info there. As well as the owner of that trucks write up on how and what he did.
