3.73 to 4.10 w/ traction
I'd like to change out my front and rear diffs to posi/locker including a gear change. Any ideas? Currently running 8.5 10 bolt with 3.73. Economically, 14 bolt, D60, or air lockers aren't feasible at the moment. Thanks, Chad.
1985 GMC K1500 350 700r4 NP208 3.73 |
#2 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
user # 2756
![]() Join Date: Jun 2001
Be thankful you have 3.73s, my 85 K5 had 3.08s! Anyway what size tires you going to run? That and off road use need to be factored into whether a good tight limited slip or locker is need for the rear. Since you'll have the diffs apart go with units that replace the open diff carrier(vice lunch box lockers).
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
I just added 35" BFG's and that's why I want to move to 4.10 gears. I'm on pavement the majority of the time and the offroading I do is mud, sand, etc., but no rock crawling or Moab-type stuff. I do occasionally have a boat behind me as well. So I guess I'm leaning towards a front and rear setup with good street manners, but the ability to get me out of a sticky situation when necessary. Thanks for the help, Chad.
cochino12
What's your True trac gear ratio? Also, how much? Shipping? What was it used in? What shape is it in? Thanks, Chad.
Maybe I should jump up to 4.56 or 4.88? Any ideas? Thanks, Chad.
#7 | |
