disassemble tilt steering column
I need to know if there is an easy way to disassemble a tilt steering column. The column i bought did not have them
I also need to know if there are supposed to any shifter detents mounted to the column tube. My standard auto shift column has a tab with several steps in it to prevent shifting back up into reverse...Thanks again.
You do not need to take the column apart just bend the linkage enough to slide them on.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
member #16
![]() Join Date: Dec 1999
The detents are inside the top end of the tilt column. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Well then, how do you remove the retainer ring and bolt from the upper part of the steering shaft? I don't see how the retainer ring comes off and it is not explained clearly in the shop manual. Thanks.
I am not sure what you mean about the retainer ring and bolt. What are you trying to take apart?
If the detent does not hold, there is a good chance the shift lever spring is broken and/or the end of the shift lever is worn. Jim |
I need to remove the steering shaft and or shifter tube just to get the stupid firewall seal and retainer on the steering column.
