Old 10-03-2004, 09:10 PM   #1
Springbear
<<< Later! Wife's Calling
Springbear's Avatar
Steel Bed, Trash or fix? Your experience?
1972 ¾ Ton, 4X4 Steel Bed Questions:
(Desired result ~ Restored pick-up like factory glove box decal.)
Dropped my dealer added aux. fuel tanks today. Two cross members are rusted badly and noticing that the bed is pitted through in one spot.
I will be disassembling the bed parts to clean up any rust. Cutting in all parts with paint and reassembling.
My body guy is estimating another 10 hours at $20 per hour to straighten the bed up.
Am I better to just replace the bed sheet metal with a new one?
What is your experience or observation on other trucks?
Martin
Springbear is offline   Reply With Quote
Old 10-03-2004, 10:00 PM   #2
I can't remember for sure, but I think you'll have to fix it unless you find some good used bedsides. I don't think anyone makes repo long bedside.
Old 10-04-2004, 10:17 AM   #3
Springbear
Springbear's Avatar
That is what I am find’ in out... I have a parts dealer in Canada that says he can deliver.. stay tuned!
Old 10-03-2004, 10:03 PM   #4
longhorn71
longhorn71's Avatar
the bed floor is herd to fix.when these trucks were new every body bought them to be used as trucks.the steel floors took a beating dents and rust are common.I would change the floor to wood,just my two cents
longhorn71 is offline   Reply With Quote
Old 10-03-2004, 10:25 PM   #5
TugOwar
Longhorn you just answered a question I have had. If it is even possible to put wood in where steel is stock. Although my steel bed floor is not in bad shape I'd like to replace it with wood. Just always loved the wood bed floors.
TugOwar is offline   Reply With Quote
Old 10-03-2004, 11:01 PM   #6
longhorn71
longhorn71's Avatar
yes in classic truckin they did it on a 72.you have to change the steel supports,front bed panel and rear crossmember behind the tailgate.IT is expensive to do but it is new and looks better
Old 10-04-2004, 12:15 AM   #7
shuttermutt
Don't say "Oops!", Doctor
shuttermutt's Avatar
Hey, that's pretty sweet. It never dawned on me you could swap 'em out like that. I might have to look into that one.
'Mutt
1968 CST LWB: R.I.P.
1967 Chevelle: TPI 454 beast
1967 C10 SWB: Claimed when Bumpster didn't put it on his list
shuttermutt is offline   Reply With Quote
Old 10-04-2004, 12:23 AM   #8
longhorn71
longhorn71's Avatar
it was in the late 2003 season it was a good article and the results were even better!!!
Old 10-04-2004, 10:20 AM   #9
Springbear
Springbear's Avatar
How much is expensive? How much time does it take? To convert to wood?
Old 10-03-2004, 10:11 PM   #10
Ooops misread I think. You'll be paying about the same, maybe more to convert to wood floor, so it's your choice really.
Old 10-04-2004, 12:54 AM   #11
passthebuck
Sisyphus was my mentor!
passthebuck's Avatar
I personally am going to go back to a steel bed. My origional steel bed is too far gone but I found a better one that still needs work. There are a few holes & a few cross pieces are toast. I think that I can make patches from my old bed & I'll use better square steel tubes that are stronger & dont catch dirt like the u-shaped channel cross braces. After repairs I'll have it Line-X'ed or whatever sort of coating. I think a truck that will live outdoors 365 & will do regular work duty that steel (coated in some way) will hold up better than wood. Will it be a work truck? Will it live outside 365?
passthebuck
#5642
-TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4.
-a 2013 Honda Civic as my "sensible" car
passthebuck is offline   Reply With Quote
Old 10-04-2004, 10:23 AM   #12
Springbear
Springbear's Avatar
No it will not be out side and it will not be a work truck. I just want to drive it on sunny days! Have you found a source for the steel bed? (Beside Patches)
Old 10-04-2004, 06:26 PM   #13
passthebuck
patches is all that I know of out there.... I just had to find a workable bed & run with that.
passthebuck
#5642
Old 10-04-2004, 07:27 PM   #14
Springbear
Springbear's Avatar
That is what I am coming to a sad conclusion.... Wonder why they don't make a repo bed... even a two piece?
Old 10-04-2004, 06:36 PM   #15
Gee_Emm
Apparently they make half sections of the floor.
http://67-72chevytrucks.com/vboard/s...1&postcount=18
Gee_Emm is offline   Reply With Quote
Old 10-04-2004, 07:28 PM   #16
Springbear
Springbear's Avatar
Cool... I am on it. Thanks for the tip!
Old 10-04-2004, 08:04 PM   #17
chucks70
I've called on these sections, would be good for patch panels with a few problems. There are no dimples where your attaching bolts go. There is no support lip around the wheelhouses and are not pre-drilled. The ends are not tapered to give that finished look at the ends of the bed. They do however have a full bedpan for a '73 and up. I don't know how close the floor is to the '67-72 but that may be an option.
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible.
chucks70 is offline   Reply With Quote
Old 10-04-2004, 08:46 PM   #18
Springbear
Springbear's Avatar
Hmmm... Any one out there...? Will a '73 fit a "72 Bed? (Sounds to good to be true...)
Old 10-04-2004, 08:01 PM   #19
Warbones
Navel Inspector
Warbones's Avatar
I'm like some of you guys. I'd prefer a steel bed over my rotted wooden one. So when I hunt for one. That's what I'll be looking for.
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 10-04-2004, 08:43 PM   #20
Springbear
Springbear's Avatar
I will let you know what I find....
