10-04-2004, 09:26 PM | #1 |
Ebay Junky
Difference between van tilt and truck tilt?
i'm not sure if i have a truck tilt in my truck or a van tilt, it is out of an 73+ truck/van though. how can you tell?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
10-04-2004, 09:42 PM | #2 |
Can you post or send a pic? In 73 the pickups were a larger diameter than the vans. The bracket is held to the column with weld nuts.
10-04-2004, 10:04 PM | #3 |
Ebay Junky
this is the only pic i have and its real crappy
10-04-2004, 10:06 PM | #4 |
You may need to take some more pics. I can't see anything there.
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
10-04-2004, 10:38 PM | #5 |
its all about the +6 inches
Are you sure about the 83 part? It looks to be a 72 - 81 (and early 82) van column.
There is no ignition witch, which was introduced in the vans in 82, and trucks in 73. |
10-04-2004, 10:46 PM | #6 | |
If I read correctly he posted 73...not 83
"Do the things you fear to do and the death of fear is certain" |
10-04-2004, 11:01 PM | #7 |
Ebay Junky
do you mean by ignition switch on the column? if so, yes there is an iginition switch.
10-04-2004, 11:11 PM | #8 |
You're right, he did say 73.
I see the ignition switch now. How did you wire it up, and what did you need to do to make the huge column fit in there? |
10-04-2004, 11:16 PM | #9 |
Ebay Junky
so it is a truck column? it was in there when i bought the truck, i'm not sure how he did it, but he wasnt planning on using the column shifter because as you can see in the pic there is a floor shifter in there, but i have since removed the center console and floor shifter and now i am going to use the column to shift. do you think i will have some problems in doing this? i havent really checked out the column internals yet.
10-04-2004, 11:56 PM | #10 |
I have one like it in mine. You have to grind the cluster opening larger. Also have to cut the column shroud shorter. Get the adapter from a local gm dealer. Its not as good as a van column though. Still has the key(so now I have two ign switches) In my opinion the only benefit is the tilt.
