![]() Join Date: Nov 2002
Collapsable steering column?
When did Chevrolet start putting the collapsable steering column in? I have a '67 and wanted to do a tilt column if possible. Since the old one would be replaced what is a closest to an easy bolt in replacement that has the nice safety feature of collapsing when in a collision?
I know, just don't get hit and its not a problem, right?
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
Careful, they attack...
I think our trucks had the colapsable column. My 69 had the 2 part shaft in it when I took it out. It's the shaft from the steering box to the bottom of the column. You can see it in the engine compartment.
Got Light Emitting Diode?
my 68 has a colapsible steering shaft. but when puting in the power steering i couldnt get to move for the life of me
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
By colapsable they mean it will colapse on impact, not move to suit your needs. You will have to break the plastic rivets that hold it up, then drive it down to the size you want. It's a PITA.
#5 | |
![]() Join Date: Aug 2001
![]() HIT IT HARDER... IT'LL MOVE. SOMETIMES YOU HAVE TO HAMMER THE SNOT OUT OF IT. ![]() ![]()
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
its all about the +6 inches
Acording to what i have read, and the few 67/68 trucks I have seen, it started in 69.
To do a tilt, you'd need the column naturally, and then the intermediate shaft. The one between the gear box and the column it's self. If you go with a van unit, you have to colapse it a couple inches to make it fit. Real easy to do, with the intermedeate shaft removed, stand it on end then pick it straight up a foot or so, and let it drop. that should break the nylon inserts. There is no reason to install new ones, it will do absolutly no good and a waste of time to do so. (I've heard many say it is needed) Your shaft will still have the colapsable feature, but it won't colapse as far. |
I just smacked mine on the floor,, several times,ok,, quite a few times, and it moved enough to fit.
#9 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
yup, that was me,, when I get answers to questions, I act on them,,, thanks fer the tip
