Old 10-05-2004, 09:34 PM   #1
ocbaud
Garage Queen Material
MF!!! thats no good!!!
i swear, i fix one thing, and another freaking thing breaks!!
i took off my valve covers today to polish them. got them all nice and pretty and put them back on.
when i go to tighten one of the nuts on the stud, it cracks the damn valve cover!!!
is there anyway to fix this? its leaking slowly whenever i drive it.
ocbaud is offline   Reply With Quote
Old 10-05-2004, 09:43 PM   #2
87 Shortwide
they are alum right? the only thing to do is get it welded up, and then smooth it back down.
Daily Driver: 1992 Blazer dropped on rallys
Project: 87 GMC shortwide, About to get a little boost
87 Shortwide is offline   Reply With Quote
Old 10-05-2004, 09:46 PM   #3
1972C10
1972C10's Avatar
HAHA . I did the same thing With a pair of M/T's I cracked one of them Tryin to get a leak to stop . Dont put so much S*** down on it next time...
Shouldnt cost but 20 dollars or so to get it fixed have it welded on the inside
Clean the crack out with a die grinder and wouldnt hurt to drill the end of the crack to prevent it from spreading..
Alot of metal shops prefer to do their own prep work though so call around first.
1972C10 is offline   Reply With Quote
Old 10-05-2004, 10:20 PM   #4
79Silv4x4
Workaholic
79Silv4x4's Avatar
I told you in a post way back to stick with chrome and you would not have to deal with the polishing
Seriously though, that sucks--I guess by the time you paid someone to weld it and deal with all of that you could buy another set. If you used a torque wrench to the Mfg specs maybe you could get a warranty claim as defective?.?.?
79Silv4x4 is offline   Reply With Quote
Old 10-05-2004, 11:05 PM   #5
Destructo
maybe try using some of those spreaders that spread the pressure out instead of putting it all on the one spot.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 10-06-2004, 12:35 AM   #6
ocbaud
the spreaders are built into the valve cover
Old 10-05-2004, 11:22 PM   #7
plumbcut
california fill
well now you know you were torqueing it way too tight. same with stamped valve covers and oil pans, install the screws with a nut driver and just snug em up good. Then re-snug in about a week. It should be a crime to touch pan/V.C. bolts with a wrench
plumbcut is offline   Reply With Quote
Old 10-05-2004, 11:27 PM   #8
1972C10
1972C10's Avatar
I use a little 1/4 rachet for all my oil pan and whatnot tightening If you get carried away you can overtorque with a nutdriver Just the same as anything else.
Old 10-05-2004, 11:29 PM   #9
Destructo
I use those T-Handle valve cover bolts, I love those things!
Old 10-06-2004, 10:39 AM   #10
corn
Put a coat of J-B Weld on the inside of the cover where its cracked. Ive used that stuff for almost everything & its never let me down yet...corn
corn is offline   Reply With Quote
Old 10-06-2004, 10:42 AM   #11
Grim Reaper
Torque on valve covers is rated in inch pounts not pound feet. "Snug" is all it takes with good gaskets.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 10-12-2004, 05:14 PM   #12
ocbaud
my dad called jegs today and they said we could ship them back and get another set
that means i'll have a nice clean set that i will use a torque wrench on from now on
i love jegs!!!
i'm using my friends moroso stamped valve covers now, and no leaks.
what would you guys recommend for a gasket that would work really well?
Old 10-13-2004, 12:04 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by ocbaud
..... i will use a torque wrench on from now on ...
Just remember that's inch pounds "NOT" foot pounds....
Old 10-12-2004, 06:02 PM   #14
86 Red_Bowtie
86 Red_Bowtie's Avatar
Fel-Pro Gaskets are good.Never hava had any problems with them leaking and have been on the truck for the last 5 years.
Sean
Midwest All Truck Nationals, Riverside, MO - 2008 - 2015
86 Red_Bowtie is offline   Reply With Quote
Old 10-12-2004, 08:09 PM   #15
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have always used Mr. Gasket Ultra Seal valve cover gaskets and to this day, never had a leak. I glue them to the valve cover and can remove the covers without messing up the gaskets.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 10-12-2004, 09:39 PM   #16
SanitysBane
fel-pro glued to the valve cover
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 10-12-2004, 10:08 PM   #17
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
I really like the high end line of Fel Pro Permadry plus gaskets. They are expensive (~$40 at Autozone) but they work great. They are rubber like modern factory gaskets and go on dry. They are reusable and have inserts to prevent overtorqing.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 10-13-2004, 12:31 AM   #18
ocbaud
i'm very happy with jegs about this. they didnt have to take them back, and most places wouldnt, seeing as i ordered them back in febuary.
Old 10-13-2004, 06:31 PM   #19
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
They didn't have to take them back anyways, conisdering YOUR goofy ass over-torqued them. :p
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 10-13-2004, 11:43 AM   #20
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
I've lucky enough to not break mine but mine are centerbolt style though. Not sure if that has helped or not. I use the fel-pro style for my truck.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 10-13-2004, 06:58 PM   #21
PHOENIX
So far I like the Moroso blue rubber gaskets.
I was using the fel-pro rubber, but they have these ridges that I think make them less affective. The moroso valve cover gasket i am speaking of is very similar material and texture to fel-pros 1-piece oil pan gasket.
I highly recommend them.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
