Old 10-08-2004, 08:04 AM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
1/2 ton 2wd lower ball joints-any diff between 67-70 and 71/72?
I know tie rods and upper ball joints are different between drum and disk equipped trucks. I was wondering if the lowers were the same or not (same part#). Something tells me they may be but I need to confirm. Long story
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 10-08-2004, 08:11 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
71-72 lower ball joints are different for sure. Not for sure on the uppers. Inner and outer tie rods are also different!
Keith
Convert to disc brakes.
Old 10-08-2004, 08:12 AM   #3
rage'nrat638
rage'nrat638's Avatar
here's where i always go...
http://www.autozone.com
rage'nrat638 is offline   Reply With Quote
Old 10-08-2004, 02:17 PM   #4
68C15
blood type; Retumbo
68C15's Avatar
the diff. is in the stud where they go in the spindle. later ones are larger & longer. they will interchange on to older arms. thats what I did since I had rebuilt my 68 arms before going to discs from an 80 C10. they bolt right up on the uppers & press right in on the lowers.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
