Decal under the hood states initial timing should be set at 0*.
Question is: Would it help my gas mileage(about 11mpg) increase if the timing is bumped to 8-10*btc. (Right now WinALDL reports very few knock counts.) And I just installed a new O2 sensor. Thanks Eddie ![]() 87 R10/TBI/5.7/Auto/3.42/10x31"AT's |
They usually say 4 degrees are safe for a stock engine and you can advance up to 6 with some performance mods. I tried 4 on my stock truck and it knocked badly when the engine was hot and I stepped on the gas.
Jason |
Doenst matter where you set the timing the computer will compensate automatically.
#4 | |
The ecm does not actually know what the base timing is. It assumes the timing is set to 0 degrees and advances or retards the timing according to the input from the various engine sensors. If you advance the base timing too much you can end up with too much advance during normal operation resulting in detonation. When this happens the ecm will have to retard the timing to where it does not knock. What you end up with is a driveability problem. |
Jason: thanks for the info.
I've adjusted the timing to 4*btc. So far no pinging. Eddie |
Try this forum for more info on tuning TBI engines.
http://www.thirdgen.org/techbb2/foru...php?forumid=17 These guys know just about everything there is to know about GM TBI. |
Unless your going to go through the trouble to get a real time set up so you can see how much timing advance, and the knock count the ECM is alowing or you dyno the car your are not going ot know if you are improving or screwing up. If you start tripping the knock sensor its going ot retard MORE then the 4 degrees you advanced it and acully make less power.
\ A lap top comuter and some sharware and a cable and you can do it. http://www.customefis.com/ Sells the cable and has a link to the site that has the Shareware and be a pall and slide the guy $10 on the pay pal for the software. That site also has a good library on how to customize the FI and will burn custom chips off of the data logs off the software.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#8 | |
Eddie |
Eddie,
I recently coverted over to TBI on my 85 and have been looking at things with Winaldl. Just curious, what numbers are you getting for knock counts? I was getting quite a few like 40 on the highway in a certain RPM/vac range, then hooked up EGR and went down to like around 3 over a 20 minute ride. |
