What do we get for $10?
Dana 60 conversion
Has anyone here ever converted a Dana 60 front axle from a dually for use in a regular fleetside 3/4 ton?
I've been told it's an expen$ive ordeal. Thanks, ![]()
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ![]() |
![]() Join Date: Mar 2003
Dana 60 conversion
For the most part it is a bolt in swap. The most expensive thing is the single wheel hub/rotor assy, actually the hub itself. They are available thru Six States
Distibutors for a somewhat reasonable price. Everything else is interchangable. OK how did my reply post get above his? DOOH! |
you could also run some rims with crazy backspacing to narrow er a little.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Would the hubs be the only parts I need to buy?
I checked Six States and they're about $400/pair. ![]()
Land Beast
do you have an 14FF. if so you could convert you rear axle with dually hubs and leave the front alone and run some hummer rims.
90' GMC 1 Ton Suburban |
im switching my dually D60 to SRW. i got lucky and found someone who had a set of SRW hubs for $150.
