Old 10-09-2004, 02:04 PM   #1
skillet
skillet's Avatar
Brake light question
Concerning the 4 wires that go to the back of the truck; light green, dark green, brown, yellow. Should power be sent down the dark green wire AND the yellow wire when you step on the brakes? The reason I'm asking is that I have no left brake light and no power down the yellow, just the dark green wire has power when I step on the brakes. Everything else back there works. Thanks very much in advance for any help.
69 SB GMC LWB Fleetside 350, 09 Pontiac Vibe 2.4 liter
skillet is offline   Reply With Quote
Old 10-09-2004, 10:41 PM   #2
jimfulco
Yes. The brake lights use the same bulb filaments as the turn signals. The yellow wire goes to the left brake/turn-signal filament.
jimfulco is offline   Reply With Quote
Old 10-09-2004, 10:46 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Try wiggiling the turn signal while your foot is on the brake pedal. Most likely (if both turn signals or your 4 ways work) it'll be a bad turn signal switch.
Old 10-10-2004, 12:42 AM   #4
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
Pull the sockets out,and make sure they are getting good contact.Bad grounds can wreak havoc too.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 10-10-2004, 09:47 AM   #5
skillet
skillet's Avatar
Yup, wiggling the turn signal switch while my foot was on the brake caused the brake light to come on, so it seems to point to the switch. I never tried my hazards, cause the little red pull is sheared off flush with the steering column. Thanks very much for everyone's help!
Old 10-10-2004, 12:24 PM   #6
Longhorn Man
Sweet.
While grounds are an issue on any older vehicle...esp if there is a wooden bed floor in the equasion, as long as the parking lights work, then 99% of the time the ground will be enough for the brake lights too.
