Old 10-10-2004, 07:15 PM   #1
68LSS1
68LSS1's Avatar
A couple Fatman and HTH pictures
Finally after 3 years of planning, buying, changing, starting over, etc I get to do some assembly. The frame is just in epoxy primer as I plan on building the truck and the dissassembling for paint/powdercoat. This first picture is of the Hot Rods to Hell kit. The only thing missing is the adjustable panhard rod (and rearend). This picture shows the adjustable spring set up. Here's a frame shot, hopefully it doesn't come out too dark. Here's a picture of the Fatman Stage III front end.
Let's try this
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 10-10-2004, 07:19 PM   #2
68LSS1
68LSS1's Avatar
http://revxtreme.com/gallery/data/50..._front-med.jpg
'68 Short Step
Old 10-10-2004, 07:20 PM   #3
68LSS1
68LSS1's Avatar
'68 Short Step
Old 10-10-2004, 07:23 PM   #4
68LSS1
68LSS1's Avatar
'68 Short Step
Old 10-10-2004, 07:27 PM   #5
68LSS1
68LSS1's Avatar
The pictures are here and I would like to thank the recently opened performance shop Rev Xtreme for the space.
'68 Short Step
Old 10-10-2004, 09:00 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
That is a sweet set-up... Are you gonna run the adjustin screw's for the rear up through the bed or just leave em adjustable from underneath???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 10-10-2004, 09:17 PM   #7
68LSS1
68LSS1's Avatar
They are adjustable from the top. There is a hole in the top frame C rail that allows me to put a socket on the top of the shaft which is a hex. It's a stepside and it will be mini tubbed so I'm hoping it will come out to where I can reach behind the wheel and adjust it. As soon as I can get some temporary wheels to fit the 8.8 in the rear and clear the 13" Baer rotors up front I'll get the bed on to start measuring for that and see how wide of wheel I will be able to run.
'68 Short Step
Old 10-10-2004, 09:45 PM   #8
gonebad2
Merciless Butcher
gonebad2's Avatar
Just wanted to say thanks for the upclose pics of the frontend. I'm picking up my '72 Blazer next weekend. I'm making it into a 2wd and that's the frontend end I'm going with except I'm gonna use airbags front and rear with a 4 link in the rear. Your project looks great. Keep us posted with pics....
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 10-10-2004, 11:05 PM   #9
PTS Kustoms
LSS1 - How do you like the fatman front and is there any pros or cons?
PTS
PTS Kustoms is offline   Reply With Quote
Old 10-11-2004, 12:17 AM   #10
lock
Insert funny comment.
lock's Avatar
Nice looking front end! Coil over and rack an pinion. That will be sweet. That come with special motor mounts?
- Mark
-My Build Thread...
-68 C10, LT1 - Undergoing Frame off resto
-86 IROC-Z T72 turbo 355, M6
-70 Camaro
http://www.iroc-ss.com
lock is offline   Reply With Quote
Old 10-11-2004, 01:18 AM   #11
68LSS1
68LSS1's Avatar
gonebad2-thanks. I would like the next project to be a Blazer or Suburban.
PTS Customs-How the HTH kit going? I can't think of any cons except for maybe price but that's not really a con as I think it's worth what they charge. Pro's are dropping some weight, having a power rack, 5" drop without dropped spindles, adjustable ride height with the coil overs, the handling of unequal length a-arms and can't forget about the "bling" factor. I think going with the Fatman kit which utilizes the Mustang II suspension and the Hot Rods to Hell truck arm improvement kit is the all out best suspension that is possible on our trucks in a kit form. Yes there are better suspensions but none that are avaible or that would require major fabrication. And when I'm done I'd be willing to put my truck up against the 'Vette suspensioned Jim Meyers frames (sp?).
lock-special motor mounts are not needed. You will need to drill a couple holes in the crossmember but the original bracket that mounted between the original crossmember and to the top of the frame can be used. You will have to make a 1/4" shim to put under the bottom of the bracket on the crossmember side is all. I want to slide my LS1 as back as far as possible so I'm just going to use one of those universal SBC engine mount crossmembers.
'68 Short Step
Old 10-11-2004, 02:16 AM   #12
NPilot1975
NPilot1975's Avatar
I am thinking about going with the Fatman Frontend. Did you add the Baer brakes on your own or is that an option through Fatman? If you laid your frame on the ground, would the crossmember touch the ground before the bottom of the frame? I want to lay my truck out on air, thinking the stage IV kit, don't know that I am going to lay frame but want to have the ability if I decide to. What add-on components did you get on the kit you ordered, looks like power rack and ?. I just want to get an idea of the final cost of the kit, I know the website says $2445. Thanx for the info.
I don't know if you already got motor mounts, but here are a sweet set:
http://performanceonline.com/store/c...7112af4ff9bdb2
1972 Blazer body...need to get a thread started for the rest of the story
NPilot1975 is offline   Reply With Quote
Old 10-11-2004, 02:25 AM   #13
Trifelynn
Trifelynn's Avatar
68LSS1....looks great. would you recommend the same set-up for a '71 blazer? What exactly did you do? I also am going to run bags, and I have looked at a lot of front ends....after doing all this...what would you recommend...
thanks
:edit: I haven't been following your progress, so sorry for the dumb question...but what year/make/model is the vehicle you are doing?
Always looking for a 2wd blazer
Trifelynn is offline   Reply With Quote
Old 10-11-2004, 02:52 AM   #14
68LSS1
68LSS1's Avatar
thanks
I'd need more info about the intended use of the Blazer before I could answer that. For a daily driver with a stock to mild (cam, headers, heads, carb) engine I think the stock trailing arm suspension is fine. Actually if the truck is never intended to hit the strip or a "highly spirited run" through some cones or road course the stock set up is fine. However if either of those are a possibility then the HTH improvement kit is a very good option. I don't think it would work well with air bags though. To me it sounds like you have a daily driver that you'd like to bag and be comfortable to drive. Then I would recommend going with a front suspension that will give you at the minimum a power rack and steering unit and some drop to start. The Fatman unit does that with some additional features also. IMHO gearboxes can't and will not ever be able to be compared to rack's. I had converted my truck (the one in my sig is the one in work by the way) already to power steering/brakes and 5 lug all the way around but my 7K pound Expedition still felt better and smoother with a rack than my truck.
'68 Short Step
Old 10-11-2004, 10:48 AM   #15
NPilot1975
NPilot1975's Avatar
How much did you give for the brakes?
Old 10-11-2004, 02:35 AM   #16
68LSS1
68LSS1's Avatar
The only add ons that I got was the polished a-arms and polished coil overs and the rack like you said. I am not sure about what brake options are available through Fatman but I think they have some or a "brake delete" option. I got my Baer brakes on my own, any kit for a Mustang II will work. I measured the angle of the crossmember and frame and it was within a tenth of a degree with my digital protractor and then I measured from the bottom of the frame to the ground and the bottom of the crossmember to the ground. From the frame to the floor I had 14 1/2" and from the crossmember I had 15 3/4" so the frame would definately hit before the crossmember if I laid it on the floor. Give Ed @ Mothertruckers a call about the Fatman kit as he is a authorized dealer and had installed quite a few of these (of course I found this out after the fact).
'68 Short Step
Old 10-11-2004, 11:06 AM   #17
68LSS1
68LSS1's Avatar
I did get a deal on them. I got them from a guy who is building a awesome pro-touring Nova. He had a design change and went with a different front suspension. I think I paid 7-800. See the legendary John Parson and his Nova at his website II Much Fabrication.
'68 Short Step
Old 10-11-2004, 04:57 PM   #18
SCOTI
SCOTI's Avatar
Parsons ChevyII is awesome.
How about a pic from the front of the crossmember. I'm curious of what the measurement is from the bottom of the front crossmember to the bottom of the frame rail to compare w/a stock crossmembers location.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
Old 10-11-2004, 05:35 PM   #19
68LSS1
68LSS1's Avatar
Are you asking from the bottom of the front crossmember to the ground and from the bottom of the frame to the ground? I measured that in a above post. It was 14 1/2" from the frame (section that cab sits on) and 15 3/4" from the front crossmember with the frame and crossmember within one tenth of a degree of being level (or whatever the garage floor is). So the Fatman unit sits up by about 1" if that is what your asking. If not run it by me again, either way I'll try and get you a picture tonught.
'68 Short Step
Old 10-11-2004, 06:55 PM   #20
SCOTI
SCOTI's Avatar
Yeah, I figured my request was confusing. I'm looking to see how far below the bottom of the frame rail the FatMans crossmember sits. So the bottom of the frame rail where the crossmember bolts up to the lowest part of the MII crossmember. I would guess-i-mate about 6" or so. It also looks (and IIRC), that no part of the steering Rack hangs below the bottom of the crossmember. Is that correct?
Anyway.... cool progress pics. Thanks for sharing.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2004, 08:28 PM   #21
GMCGRANDS
Looking good 68LSS1. Keep the pictures coming as you get along.
Mark
72'GMC Sierra Grande 2wd SWB, Fatman stageV IFS, 6.0 liter LQ4 Gen 3 and 4L80E under construction
05' GMC Sierra Denali LQ9
GMCGRANDS is offline   Reply With Quote
Old 10-11-2004, 08:41 PM   #22
68LSS1
68LSS1's Avatar
SCOTI, I added 4 pictures, take a look and see if it's what you're after. If not let me know. The pictures are here. Yes the bottom of the frame where the Fatman crossmember bolts up is the lowest part. Even the lower a-arm should be at this height when properly adjusted. GMCGRANDS, thanks I definately will.
'68 Short Step
Old 10-11-2004, 09:05 PM   #23
SCOTI
SCOTI's Avatar
Yep it looks to be between 6-7". The pic #001 was about where I was looking for the measurement (if you get the chance next time your out in the garage wrenching that would be cool).
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-11-2004, 09:19 PM   #24
68LSS1
68LSS1's Avatar
OK, I get where you want the measurement. Dang SCOTI , you're good. It was right at 6 1/2".
'68 Short Step
Old 10-11-2004, 10:44 PM   #25
SCOTI
SCOTI's Avatar
Red face
Awe shucks . . ...
Thanks again for that info. I can't wait to see more pics. It's also nice to see someone from here posting over on the pro-touring site. If I wasn't determined to finish my truck I would be knee deep in something classic that handles on rails.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
