WTB Frame rivets
Where can a person buy rivets for the frame crossmembers?
And, no I do not want to use bolts. I need to replace several items and would like rivets.
72 3/4 4x4 350 4spd 72 3/4 4x4 350 auto 2004 Duramax Silverado 4x4 2006 Duramax Crew cab 4x4 2010 Harley Ultra Limited 2011 Harley Street Glide |
![]() Join Date: Feb 2003
rivets
I looked all over he11 for them about a year ago. Finally gave up. I found smaller ones at a tractor supply place. The only place I didn't try was a GM dealer.
Active Member
![]() Join Date: Oct 2002
Frame rivets
I got mine from Ed Cooper at "MOTHER TRUCKERS" # (941) 756-4905
I only needed four of them, so Im pretty sure he still has some. |
I have 200 in stock. 1.00 each.
Rest in Peace Ed. Thanks for all the good times. |
![]() Join Date: Mar 2004
Ed is there a tool you have to buy to install them? Thank's Jason.
Ed, I will call you. I need about 15-18.
! made a tool out of 3/4 round stock with the correct cove to fit the rivets contour when set, we use in an air chisel and a frame clamp that hooks over the top edge on the outside of the frame to hold the hot rivet while i beat it in to place.
Tried to call you today. My mistake. It was 3:15. Central time. I forgot you were in Florida. I will call you tomorrow.
