Old 10-14-2004, 08:24 PM   #1
andrew king
LOW OIL pressure where to mount the sender?
I fixed the backfire and while breakling in the cam I noticed Oil pressure is only at 20 psi at 2000 rpm I changed the gauge and still got the same thing. The sender is located at the front of the motor on the drivers side down by the oil pan. All the gauges and senders I have installed usually mount up by the oil filter. Where should I mount the sender to get the correct pressure. Also could the factory oil cooler cause low oil press??jsut a thought. By the way the motor is a 454 . thanks, Andy
andrew king is offline   Reply With Quote
Old 10-14-2004, 08:34 PM   #2
SanitysBane
were it is mounted you are getting the oil presure once it has gone threw everything, pull the plug out above the oil filter, and install it in the normal spot.
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 10-14-2004, 10:43 PM   #3
Jonboy
Slots go on anything!
either there or behind the intake on top of the engine
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-15-2004, 07:35 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A small block is the one that goes on top of the engine, not a big block.
He has a big block, it goes above the oil filter.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
