10-15-2004, 12:06 PM | #1 |
Fetzer Valve Technician
Anyone with a Hollander Manual?
Could you look up and see what front disc brakes interchange on a 1972 Chev 4x4?
Thanks.
1972 Chevy K10 SWB |
10-15-2004, 01:12 PM | #2 |
Here you go (I did a cut and paste so don't think I typed it all):
BLAZER/JIMMY (full size) 71-76 4x4 BLAZER/JIMMY (full size) 77 4x4, early CHEVROLET PICKUP TRUCK 71-76 10 Series; 4x4 CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, early GMC PICKUP TRUCK 71-76 1500 Series; 4x4 GMC PICKUP TRUCK 77 1500 Series; 4x4, early SUBURBAN 71-76 10 Series; 4x4 SUBURBAN 71-76 1500 Series; 4x4 SUBURBAN 77 10 Series; 4x4, early SUBURBAN 77 1500 Series; 4x4, early 325068 $290 obs Early '77 inner bearing stpd. LM603049/LM603011; late '77 inner bearing stpd. LM104949/JLM104910. Rotor same as 1501. (below is 1501 applications) BLAZER/JIMMY (full size) 77 4x4, late BLAZER/JIMMY (full size) 78-82 4x4 BLAZER/JIMMY (full size) 83-91 CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, late CHEVROLET PICKUP TRUCK 78-88 10 Series; 4x4 CHEVROLET PICKUP TRUCK 89-91 1500 Series; VIN model "V" (4x4) GMC PICKUP TRUCK 77 1500 Series; 4x4, late GMC PICKUP TRUCK 78-87 1500 Series; 4x4 GMC PICKUP TRUCK 88-91 1500 Series; VIN model "V" (4x4) SUBURBAN 77 10 Series; 4x4, late SUBURBAN 77 1500 Series; 4x4, late SUBURBAN 78-87 1500 Series; 4x4 SUBURBAN 78-88 10 Series; 4x4 SUBURBAN 88-91 1500 Series; VIN model "V" (4x4) Rotor same as 1522. (below is 1522 applications) CHEROKEE 77 late, hub & rotor CHEROKEE 78-83 hub & rotor GRAND WAGONEER 84-91 hub & rotor J-SERIES TRUCK 77 J10 (6 stud wheels), late, hub & rotor J-SERIES TRUCK 78-88 J10 (6 stud wheels), hub & rotor WAGONEER 77 late, hub & rotor WAGONEER 78-83 hub & rotor
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
10-15-2004, 03:32 PM | #3 |
I am not really sure how to read that. I assume that the first section is for Calipers? Am I correct in the assumption from the info above that the 72 rotors do not interchange with the 73 rotors? Can you also give me interchange info on the spindles?
10-15-2004, 07:39 PM | #4 |
I have the CD version of Hollander on my work computer and when you do a search you have to put "front brakes". It will not let you put rotor. It will let you put caliper and spindle. The rotors on any of the listed vehicles will work (basically 71-91). I will not be at work until Tuesday so I will check on the calipers/spindles then. Hope this helps.
10-19-2004, 10:51 AM | #5 |
Here is what I came up with on calipers/spindles.
Calipers BLAZER/JIMMY (full size) 71-78 Front; 4x4 CHEVROLET PICKUP TRUCK 71-78 Front, 10 Series; 4x4 CHEVROLET PICKUP TRUCK 71-78 Front, 20 Series; 4x4 GMC PICKUP TRUCK 71-78 Front, 1500 Series; 4x4 GMC PICKUP TRUCK 71-78 Front, 2500 Series; 4x4 PONTIAC 69-70 Front SUBURBAN 71-78 Front, 10 Series; 4x4 SUBURBAN 71-78 Front, 1500 Series; 4x4 SUBURBAN 71-78 Front, 20 Series; 4x4 SUBURBAN 71-78 Front, 2500 Series; 4x4 Spindle (early) BLAZER/JIMMY (full size) 71 4x4 CHEVROLET PICKUP TRUCK 71 10 Series; 4x4 CHEVROLET PICKUP TRUCK 72 10 Series; 4x4, early GMC PICKUP TRUCK 71 1500 Series; 4x4 GMC PICKUP TRUCK 72 1500 Series; 4x4, early SUBURBAN 71 10 Series; 4x4 SUBURBAN 71 1500 Series; 4x4 SUBURBAN 72 10 Series; 4x4, early SUBURBAN 72 1500 Series; 4x4, early 3979676 R. or L. Early '72 used on vehicles with axle ident. 603351 or 603352; late '72 used on axle ident. 603333 or 603334. Spindle (late ) BLAZER/JIMMY (full size) 72 4x4 BLAZER/JIMMY (full size) 73-75 4x4, spindle BLAZER/JIMMY (full size) 76 4x4, horizontally mtd. (tie rod) grease fittings, spindle BLAZER/JIMMY (full size) 76 4x4, vertically mtd. (tie rod) grease fittings, spindle BLAZER/JIMMY (full size) 77 4x4, small bearing (1-25/32" I.D.), spindle CHEVROLET PICKUP TRUCK 72 10 Series; 4x4, late CHEVROLET PICKUP TRUCK 73-75 10 Series; 4x4, spindle CHEVROLET PICKUP TRUCK 76 10 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle CHEVROLET PICKUP TRUCK 76 10 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle CHEVROLET PICKUP TRUCK 77 10 Series; 4x4, small bearing (1-25/32" I.D.), spindle GMC PICKUP TRUCK 72 1500 Series; 4x4, late GMC PICKUP TRUCK 73-75 1500 Series; 4x4, spindle GMC PICKUP TRUCK 76 1500 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle GMC PICKUP TRUCK 76 1500 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle GMC PICKUP TRUCK 77 1500 Series; 4x4, small bearing (1-25/32" I.D.), spindle SUBURBAN 72 10 Series; 4x4, late SUBURBAN 72 1500 Series; 4x4, late SUBURBAN 73-75 10 Series; 4x4, spindle SUBURBAN 73-75 1500 Series; 4x4, spindle SUBURBAN 76 10 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle SUBURBAN 76 10 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle SUBURBAN 76 1500 Series; 4x4, horizontally mtd. (tie rod) grease fittings, spindle SUBURBAN 76 1500 Series; 4x4, vertically mtd. (tie rod) grease fittings, spindle SUBURBAN 77 10 Series; 4x4, small bearing (1-25/32" I.D.), spindle SUBURBAN 77 1500 Series; 4x4, small bearing (1-25/32" I.D.), spindle
10-19-2004, 11:22 AM | #6 |
Thanks Man.
10-19-2004, 11:22 AM | #7 |
jjr
will a complete 2wd 12bolt rear out of a 67 be the same as a 66 Thanks Kevin
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
10-19-2004, 11:51 AM | #8 |
djracer, here is what shows for a 66 C-10 2WD rear axle assembly (drum to drum):
CHEVROLET FORWARD CONTROL 65-69 10 Series CHEVROLET PICKUP TRUCK 65-66 10 Series 4x2; 12 bolt cover CHEVROLET PICKUP TRUCK 67 10 Series 4x2 CHEVROLET PICKUP TRUCK 68-69 10 Series 4x2; 12 bolt cover, coil springs GMC FORWARD CONTROL 65-66 1000 Series GMC FORWARD CONTROL 67-69 1500 Series GMC PICKUP TRUCK 67-68 1500 Series 4x2; 12 bolt cover GMC PICKUP TRUCK 69 1500 Series 4x2; 12 bolt cover, coil springs SUBURBAN 65-66 10 Series 4x2; 12 bolt cover SUBURBAN 67 10 Series 4x2 SUBURBAN 67-68 1500 Series 4x2; 12 bolt cover SUBURBAN 68-69 10 Series 4x2; 12 bolt cover, coil springs SUBURBAN 69 1500 Series 4x2; 12 bolt cover, coil springs Assembly includes hubs & drums. On '65-66 the sway bar attaches to a cast ear on the carrier. It may be necessary to change the parking brake cable when interchanging.
10-19-2004, 11:56 AM | #9 |
Thanks JJR
