Old 10-16-2004, 12:21 PM   #1
elmono
15 inch 6 lugs on 14 bolt?
I'm considering upgrading my 10 bolt to 4.56 posi, but it's almost $2000 to do it. So, can I get my 15x8 6 lug wheels on this axle? Will it be cheaper to just upgrade the 10 bolt? Thanks, Chad.
1985 GMC K1500 350 700r4 NP208 3.73
elmono is offline   Reply With Quote
Old 10-16-2004, 02:21 PM   #2
1972C10
1972C10's Avatar
If you get a Semi FLoating 14 bolt.
1972C10 is offline   Reply With Quote
Old 10-16-2004, 06:39 PM   #3
smokkey1
Land Beast
for the 14 FF you can get an 8 - 6 lug adapter.
the 14 SF is 8 lug up to 91' but they change in the IFS trucks to 6 lug IIRC. but the shock mounts and spring perchers are different. and there harder to find. I bought an 14FF for my sub yesterday for $85 4.10's an open carrier but it was out of an 1 ton truck. so I need to change the sprind perches and shock mounts. you want to get the 3/4 ton 14FF it's an direct bolt in all you need is an conversion u joint.
90' GMC 1 Ton Suburban
smokkey1 is offline   Reply With Quote
