Old 10-17-2004, 01:45 AM   #1
bucket
bucket's Avatar
puff of blue smoke
noticed today that when i press in the clutch to shift from third to fourth (3,000 rpm), i will get a quick puff of blue smoke from the tailpipe when the clutch is released. 4,000 miles on 327 since complete stock rebuild. thoughts?
bucket is offline   Reply With Quote
Old 10-17-2004, 01:49 AM   #2
sdkid
Valve seals or guides. What was done to the heads for the rebuild?
sdkid is offline   Reply With Quote
Old 10-17-2004, 01:51 AM   #3
bucket
bucket's Avatar
machine shop rebuilt them. i'm thinking they were knurled which might be the problem?
Old 10-17-2004, 01:55 AM   #4
sdkid
I hate knurling, just a band-aid. Could be your problem.
Old 10-18-2004, 10:33 AM   #5
bucket
bucket's Avatar
just got off the phone w/ a mechanic i know.............he thinks it might be a ring since it also is smoking a little on hot startup. i don't want to tear this thing apart already!
Old 10-18-2004, 10:47 AM   #6
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
What is knurling?
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 10-18-2004, 02:40 PM   #7
curbyk
69 C-10 project
curbyk's Avatar
it is like what you get on some of the handles a ratchet or breaker bar has for grip, cross patterns, it pushes the metal up in some places to take up the play in the guide, usually only temporary.
69 C-10 Work is complete
curbyk is offline   Reply With Quote
Old 10-18-2004, 02:43 PM   #8
chickenwing
Is this done on the head itself, inside or outside of the guide? Not on the valve!?
Rich
Old 10-18-2004, 03:21 PM   #9
mocwon
Keep On Truckin'
mocwon's Avatar
Its done on the inside wall of the valve guide where the valve stems fits.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 10-20-2004, 06:39 PM   #10
bucket
bucket's Avatar
well i had a leak down test done today.............inconclusive on the oil burning. all cylinders are consistent w/in 10% and are all like 95% sealed. spark plugs were all consistent too. they looked pretty good. the mechanic told me to put some more miles on it till a suspect cylinder shows up (like a misfire). asked him about the knurling (although he's the one did them, but still is a straight shooter so i believe him) and he said that he didn't think that would be the issue. said that since they had not been knurled before, they had a quite a bit of material to work with and they wouldnt be leaking enough to exhibit these symptoms. he did acknowledge that both sides are burning to some extent.
