Old 10-19-2004, 09:56 PM   #1
Solver
Solver's Avatar
Door panel installation ?
A friend of mine is redonig his interior on a 69 and bought new vinyl door panel covers. Who has installed new ones? What should he be on the look out for for problems? Did you glue front and back or just back overlap? I would appreciate any info or suggestions.
Once he gets it together I am sure I can convince him to join and show some pics of his truck.
Thanks guys
  • 1972 Cheyenne Super 20 LWB-Blue
  • 1972 Cheyenne Super 10 LWB-Black
  • 1972 Cheyenne Super 10 LWB-Red
  • 1972 Cheyenne Super 10 LWB-green
  • 1972 GMC 4x4 LWB-White
  • 1971 Cheyenne 10 LWB-Ochre
  • 1971 Cheyenne 20 Longhorn-Copper
  • 1971 Cheyenne 20 Longhorn-Black
  • 1969 Custom 10 LWB-lt blue
  • 1968 GMC 3/4 ton-green
  • 1968 1/2 ton swb stepside-silver
  • 1967 Chevrolet CST 10 LWB-green
  • 1967 Chevrolet custom 20 LWB-Maroon
Solver is offline   Reply With Quote
Old 10-19-2004, 11:50 PM   #2
HuggerCST
HuggerCST's Avatar
Haven't done it yet, but I'm gearing up to do it now, so I'll be watching this thread for tips also. I've got the new covers, and have a couple of used metal doorpanels that I was planning to clean, sand, and coat with POR15, since they seem to rust at the bottom around the screws.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 10-20-2004, 06:59 AM   #3
MOTHERTRUCKERS
It takes 2 guys to pull at all 4 corners to slightly stretch the wrinkles out before letting it make contact, we spray the back of the vinyl and the panel with contact cement,let it dry to the touch,align it and put down. on the back corners we use a razor blade to make small pie cuts so it forms around the curve with no wrinkles and when you have the corners done spray it and put them down while stretching them slightly, trim the door handle and window crank hole with pie cuts and glue then to the back and install the escutions, the door panel bottom screw holes can be done using an awl to open them up and using the correct door panel washers and screws. NOT finish washers.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
