Old 10-20-2004, 12:12 PM   #1
raphyel
Testing dash gauges
ANyone know how I can test me gauges on my dash using voltage? I was gonna just plug in a 12 v battery and see if I got movement, but not sure if they run on a reduced voltage or not. Anyy help will be appreciated
raphyel is offline   Reply With Quote
Old 10-20-2004, 10:44 PM   #2
blood62
blood62's Avatar
Do not plug in a 12v bad idear your likely to blow or pin them, is thier anyway you can get a votage mesurment or find out the ranges using a shopmanual. I do know that almost all votage based gauges usaly operate on low votages if they are reduced at the dash or from the sensor i cant tell you for shure i will try to find out by tomorow.
what gauges are you trying to test anyway?
blood62 is offline   Reply With Quote
Old 10-21-2004, 12:26 AM   #3
blood62
blood62's Avatar
here is some proof that connecting directly to 12V might be a bad idear
http://www.fortunecity.com/silversto.../svc8x66.htm#6
im still gona look for a voltage range that you could apply to em to test them
Old 10-21-2004, 12:48 AM   #4
blood62
blood62's Avatar
Ive been looking for 3 hours its 1 am ill pickup on it tomorow hang in thier
Old 10-21-2004, 10:04 AM   #5
raphyel
Gauges
I recently bought a tach dash for a 60 - 63 I have gas gauge, oil pressure, Temp, Tach, and battery gauge. I know there must be a way to test them, but I am not sure how, and I dont want to have to replace them because I blow them up, so I am looking for a easy way to establish continuity.
Old 10-21-2004, 12:35 PM   #6
60-66 Nut
Professional Beer Tester
Raphyel, does your truck have gauges already? Are you wanting to know how to hook up the gauges or to test them? Or both? Might be able to help you if you still need. Just let me know.
60-66 Nut
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 10-21-2004, 01:54 PM   #7
raphyel
Testing
I just need to test them. The unit I bought was untested and I dont want to install it without testing, as I have extra gauges if something is bad I can replace it.
Old 10-21-2004, 02:48 PM   #8
blood62
blood62's Avatar
is thier any way you could take a voltage mesurement off sensors... also check the back of the gauges for serial numbers somthing indicating operating ranges
any way ive been sick all day or i would have gone outside and found out for my self
if i do feel better I will go look
Old 10-21-2004, 03:21 PM   #9
60-66 Nut
If you already have gauges in your truck, then the best way to check the new cluster is to hook it up to the truck. Even if you don't install it, just hook up the wires to see if it works with the correct senders. I think Ford and Dodge were the only ones to use voltage limiters on their old gauges. I've never seen them on the old GM trucks. You can check the voltage to the fuel and temp gauges on your truck to be sure. The oil pressure gauge on most of these old trucks is mechanical, you should be able to check it with 30-40 PSI air pressure(be carefull-it could spit out a little oil when you take the air away). The amp gauge should connect inline between the battery and the accessory wire. It would be hard to test it witout a load. I have checked the sender type gauges like the fuel and temp gauge by hooking power to the hot side and just momentarily touching ground to the sender side, but I do not recommend it, you could easily fry a gauge if not carefull. Besides, this will only tell you if the gauge moves or not; it won't tell you how accurate it is. Hope this helps, best of luck.
60-66 Nut
85 GMC Short Bed
86 GMC Short Bed
92 GMC 1500
Old 10-23-2004, 12:47 AM   #10
raphyel
Update
I used a 6v lantern battery to test the gauges and all of them show continuity. The gas hand the voltmeter, the temp all shoe continuity. I will have to wait to test the tach and oil pressure gauges. But the best thing is that the 6v battery was sufficient to activate the electromagnets. but didnt hurt the coils.
Old 10-25-2004, 09:33 AM   #11
blood62
blood62's Avatar
ill remeber that though i probly will not need to test much most of my indicators are just a light bulb
