Old 10-24-2004, 09:43 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Egr
Well, what is it? If i disconnect it and plug the hole, will performance and MPG suffer or improve? If i shouldn't disconnect it for performance, should i take it out and clean it or replace it?
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-25-2004, 10:54 AM   #2
Prerunner1982
Prerunner1982's Avatar
if you dont have emissions testing you can put a block off plate on it and be good. but if you have testing, replace it if you think its causing you problems.
Prerunner1982 is offline   Reply With Quote
Old 10-25-2004, 02:40 PM   #3
PHOENIX
Is the EGR giving you problems now?
If you disconntect the egr you may suffer some performance at higher rpms.
The egr helps cut down on pinging.
I have a brand new EGR and I dont know whats wrong with my setup but it causes the engine to stumble off idle. Most of the time I have the line off and plugged, but I have been trying to get it fixed and right.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 10-25-2004, 04:24 PM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
I don't think its messed up, i was just curious if it gets clogged or could need replacing after 24 years. Last night i was making out a list of NEEDS for birthday and xmas, and was curious what all emissions stuff my dad eliminated. Now that its light outside, im gonna go look for it. he said he eliminated all the emissions stuff he could figure out. i was just curious as to what it is.
so
WHAT DOES IT DO?
Old 10-25-2004, 05:05 PM   #5
Jonboy
Slots go on anything!
EGR stands for Exhaust Gas Recirculation. It allows exhaust to be reburned, thereby reducing emissions. The best way to check the operation of the valve is to put your fingers under it at idle, and gently raise the valve. If the vehicle stumbles, it is working. Likewise, if you cannot get the valve to move, it will need to be replaced.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 10-25-2004, 06:49 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
ahh, sounds like its gonna stay on there
Old 10-25-2004, 06:58 PM   #7
C&C Chevy
C&C Chevy's Avatar
From what I understand it's better to replace it rather than cleaning it..
Robert
Current:
1986 SWB Silverado 4.3 / TH400
Past:
1985 SWB Silverado 305 / TH350 - sold 1995
1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007
C&C Chevy is offline   Reply With Quote
