Old 10-24-2004, 10:39 PM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Question Those with 20's, I need help!
I have been searching the net for some rims for my '70 shortbox fleetside project. I see there are all kinds of offsets out there. From -30mm, -5mm, +10mm, +14mm, etc. etc. etc.
And they also show a BSM number. Now is this backspacing?
Please post what size of rims you have, and what your offset and backspacing is please.
I am totally confused. Please help!
Here is a link for example: http://www.aewheel.com/wheels_detail.cfm?id=11
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 10-24-2004, 11:12 PM   #2
TheFabShop
Look to the left under BSM that is the b/s.
TheFabShop is offline   Reply With Quote
Old 10-24-2004, 11:44 PM   #3
REPO1
Shortbox wanna-be.
REPO1's Avatar
That is kind of what I figured. But what BSM and Offset am I looking at for my truck? I was hoping for either a 20x8 or 20x9.5 in the rear and either 20x8 or 18x8 in the front.
Old 10-26-2004, 02:20 PM   #4
Truckhead
18436572
Truckhead's Avatar
I can say a 20x9 off an escalade will fit F&R with 1/2inch spacers out back and alittle grinding of the hub up front. I ended up having to install longer studs for the spacers,then i had to cut about 3/4 of an inch off the studs to make the chrome closed lugs to fit just right. But, to fit the longer studs i had to have the stud holes machined out alittle to fit the studs as they were alittle bigger. It's all good now and everything looks and works fine.
Truckhead is offline   Reply With Quote
Old 10-26-2004, 06:21 PM   #5
turmoline
I have 20x9.5 out back w/ 0 offset and a 5.25 backspacing. 20x8 up front w/ 0 offset and a 4.5 backspacing. backspacing is a measurement from the mounting point of the rim to the outside edge. Offset is a measurement from the center for and aft. for instance a negative offset(large backspacing) will give you a shallow looking rim. hope this helps.
turmoline is offline   Reply With Quote
Old 11-03-2004, 06:45 PM   #6
grnddwn
belly dragger
grnddwn's Avatar
BSM is backspace my 20s have a 4 3/4 " back space
grnddwn is offline   Reply With Quote
