Old 10-26-2004, 12:19 PM   #1
ianjenkins
New to the 4x4 thing need some suspension advice
I recently purchased a 71 ½ ton that has been converted to a 4x4. It has a 2” suspension lift (front and back) but the front leaf springs are completely shot (sagging under the weight of a 402 BB). With this said, I want to replace the springs and shocks but don’t want to end up with the same problem. I’d like to stay with the 2” lift but should I put back heavy duty front springs? I’m considering HD 2” lift springs from www.suspensionconnection.com Link: http://www.suspensionconnection.com/...on/182612.html.
Will this be enough to compensate for the BB or should I add-a-leaf?
Also, with the 2” lift on the front with an “add-a-leaf” should I go with the 3” rear?
By the way, I’ll be using this truck periodically for hauling a bass boat but not for wheeling.
Thanks for your help,
Ian
ianjenkins is offline   Reply With Quote
Old 10-26-2004, 01:34 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I have the 2" HD lift w/ a SBC. I netted about 3.25" of lift. So w/ your BBC you should be right in there for 2" of lift. The add-a-leaf could make it stiff.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
