Old 10-28-2004, 09:47 AM   #1
GreyHoundSteve
Painless harness at a retail store?
Hello, Im not sure if this is the right place to ask this but does anyone know if any other retail auto part stores carry "painless wire harnesses"?
I know autozone does but part #10206 is out of stock and autozone cant order it unless its available where as summit can place an order for you ahead of time but i have to use a retail auto parts store to purchase this because i am running the expense through my company and so i have to get it from a typical retailer (dont ask me why).
Another solution would be to order another brand harness from a retailer but im not sure if any other brand is available ? Does anyone know it any retail auto part stores sell any harnesses make for our trucks?
Thanks in advance.
GreyHoundSteve is offline   Reply With Quote
Old 10-28-2004, 03:41 PM   #2
cib101abn
Screaming Eagle
O'Reilly's hve them, not sure if that chain is near you. You can go to Painless wiring on the internet and it will have a link for authorized dealers based on your zip code. They don't publish prices on the web because it is competive between dealers. hope this helps
cib101abn is offline   Reply With Quote
Old 10-28-2004, 04:30 PM   #3
dinnut
dinnut's Avatar
so cal speed shop sells them.
http://www.so-calspeedshop.com/index2.html
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 10-28-2004, 04:59 PM   #4
GreyHoundSteve
Thanks guys. I called autozone and oreileys and both cant get them for at least 2 weeks. I talked to painless and they are out of stock and so im trying to find someone who has one in stock and so far it looks like jegs ans summit are the only way to go.
I guess im just going to wait out the 2 weeks and try to get one from autozone. I figure 2 weeks is worth $300.
Old 10-28-2004, 05:36 PM   #5
UP GRADE
one set closer
UP GRADE's Avatar
this might work for you and a hole lot cheaper. http://www.ezwiring.com/
UP GRADE is offline   Reply With Quote
Old 10-28-2004, 06:59 PM   #6
GreyHoundSteve
Ive seen this kit and was considering it but i was told that it didnt come with all the factory plugins and my harness is shot including all the connectors.
