10-28-2004, 10:40 PM | #1 |
BlahBlahBlah
wheel ? txfirefighter
i really like the overall stance of your stepside and the look of your new tires and wheels. i think ill go for a similar look on my rig. im going to order some new wheels (not cragars) but since i have a burb i was thinking of going to 15x10 in the rear. is your backspacing 4.5? if so would i still go 4.5 on the 15x10's? i'll think ill be using same tire size as you...thanks,CG
10-29-2004, 07:40 AM | #2 |
Watch out for your cornhole !
I have 15x8 with 4.25 backspacing on all 4 corners.
I don't think you could get a 10 under the truck as low as it is. Mine is very close to the fender lip. It doesn't rub or anything, just too close to slip your hand in between fender and tire.
10-29-2004, 09:16 AM | #3 |
BlahBlahBlah
ok thanks for the info...i guess its 15x8 all around then...i imagine the wheel tire clearance is pretty close to the same on your truck and my burb
