Old 11-01-2004, 11:45 PM   #1
ktear
ktear's Avatar
Suspension Lift
I just purchased a 70 Blazer and was looking to put a 4" suspension lift on it. Planning on doing the leafs in the front & rear, no blocks. What's the best kit to buy for this year Blazer? Also, I've never installed a lift on a vehicle, is there anything else I need to be aware of that isn't really described in the installation procedures?
Also, where's the best place to buy the parts to rebuild the front suspension and replace the body mounts?
ktear is offline   Reply With Quote
Old 11-02-2004, 10:02 AM   #2
meathead95
computer illiterate
meathead95's Avatar
wher are you from? i have a used 2" lift in tn for sale front springs and shocks, rear blocks, and i have some new poly bushings i can throw in for 200$
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 11-02-2004, 04:23 PM   #3
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WELCOME TO THE BOARD FROM W. TN.
PLEASE UPDATE YOUR SIG SO WE KNOW WHO,
WHAT, AND WHERE YOU ARE. (UNDER USER CP)
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 11-02-2004, 04:54 PM   #4
AK|Bandit
AK|Bandit's Avatar
I've heard good things about Tuff Country's (not Rough Country) EZ-Ride lifts. I was going to buy that exact lift, but then I changed my mind and decided that I wanted more lift and bigger tires
I sure wish they made an 8" suspension lift!
http://www.suspensionconnection.com/...on/146134.html
It's better to wear out than rust out!
AK|Bandit is offline   Reply With Quote
Old 11-02-2004, 05:16 PM   #5
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I've always heard good things about superlift. I have a Rancho 6" w/ blocks on my '69 and it is pretty stiff. My '72 has a 4" lift with helper springs and blocks in back and it is fairly smooth. I think it is a Rough Country, but it was installed by the PO so I'm not sure.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-02-2004, 05:23 PM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
When I Drove Mine Home The Night They Took It Off The Transport
I Was Amazed At How Smooth The Ride Was In Mine, I Just Figured
With 35" Tires It Would Ride Rough, Not, Smooth As Silk, I Could
Not Be Happy'r, Oh Yea, I Think They Are Rough Country, It's Listed
On My Post For "november Blazer Of The Month" On Contest Board.
Old 11-02-2004, 06:31 PM   #7
ktear
ktear's Avatar
I'm from Louisville KY.. I was really wanting to go with the 4" lift, so I could put 33x12.5's under it. I also wanted a kit with the springs for front/rear, no blocks. I was looking at the Tuff Country EZ-lift, but wanted to get an opinion first. I also noticed that this year has the 6 lug pattern, so it looks like I'll be buying some new rims also. Is the selection limited in the 6 lug pattern?
Old 11-02-2004, 06:37 PM   #8
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
ktear - IS THE 6-LUG RIM SELECTION LIMITED ???
YES AND NO, LOTS OF STUFF OUT THERE, BUT NOT REALLY LOTS
OF COOL STUFF OUT THERE, GOOD LUCK FINDING WHAT U WANT.
Old 11-02-2004, 07:10 PM   #9
smokekiki
Mike
smokekiki's Avatar
I have a tuff country e-z ride on my blazer.It rides better than the old stock springs and shocks.i am running rs9000's from rancho.Pick up any 4 wheel mag.lots of tires and wheels to checkout.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 11-02-2004, 08:02 PM   #10
bouncytruck
SKINNY TIRES RULE!
Some lifts move the rear wheels forward a bit. There is a product called ZERO RATES that will re-center your wheel and adjust the angle of the pumpkin. I'm not sure what lifts, etc., they work with though. Yukon might be running them on his flat bed.
bouncytruck 1972 K5
Old 11-02-2004, 08:09 PM   #11
blazerholic
I am a Gov't Mule
blazerholic's Avatar
Yeah, what he said. I think the zero rates were designed for the shackle flip since the longer length at the rear of the spring causes the wheel to move forward a bit.
...to die in the saddle must be my destiny, to ride this rockin' horse I must be crazy...
blazerholic is offline   Reply With Quote
Old 11-02-2004, 11:15 PM   #12
ktear
ktear's Avatar
smokekiki - How was the fit for the 35" tire under the 4" lift? Did you have to trim any sheetmetal or anything?
70 Blazer - BDS 4" Lift, 33x12.50's. 307, 4bbl, HEI, Headers.
70 Z28 Camaro - Frame off restoration. 383, 700R4, 4:11 12-Bolt.
01 SS Camaro - SLP Bolt-on mods.
77 Monza - Drag car, ongoing project.
Old 11-03-2004, 01:03 AM   #13
smokekiki
Mike
smokekiki's Avatar
No trimming,but,You can't do much wheeling off road without hitting.It is for street only.
Old 11-03-2004, 04:14 PM   #14
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
WELL SAID, MINE IS 4" FRONT & 6" REAR ( HIGHER IN THE REAR TO OFFSET
THE WEIGHT OF THE DOUBLE WALL TOP I GUESS ) NO TRIMMING NEEDED,
BUT NO BAJA, ROCK CLIMBING, DITCH CLEANING, TRAIL RIDE'N ALLOWED.
Old 11-03-2004, 05:27 PM   #15
SteedaLX
I bought a superlift system for my 71 Jimmy. The quality is very nice but I think the springs are too stiff for my taste. If I were you I would use either BDS or Tuff Country springs for the front. All I have heard is good things about both. For the rear I would personally use a shackle flip. Check out www.offroaddesign.com. They make a 2 1/2 and 4 inch flip. So you could use the a 4" flip and your stock springs or the 2 1/2" flip and pick up some 2" rear springs.
1971 GMC Jimmy
6" Superlift w/ 35" tires
Chattanooga, TN
SteedaLX is offline   Reply With Quote
Old 11-04-2004, 08:40 AM   #16
ktear
ktear's Avatar
Thanks for all the good info. I'll let you guys know which way I decide to go.
