Rear Frame Rehab/Resto
I finally got around to pulling the bed of my truck and cleaning things up. You will have to pardon the use of wheels as jack stands but I used mine to support the bed. I have had the overload springs and new coil springs for a couple of years now. Everything disassembled better than I figured. I only had to cut one axle u-bolt. I used Eastwood Rust Inhibitor Paint on the frame. Now for a new exhaust pipe. Hopefully these pics will post.
Before ![]() ![]() After ![]() ![]()
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed |
Looks good. How did the eastwood paint go on? I have been up in the air about it or POR15. What did you think about sprayability etc? Is it worth the money and can it be top coated?
That looks great! I am going to be doing the same job as soon as I finish the front!
Alex 1971 Lil' Red 350 SBC 700R4 |
my gas saver
hey jjr that looks sweet. please share with us on how you like it and how it applied (spray/brush). i want to use this stuff for my frame and this would help alot, thanks, eric.
85' SWB, 4.3/TH350, getting ready for paint 84`SWB, 462ci./TH400, cowl hood, 15" billet spec., flows, blazer buckets/console, flat black 71`SWB, project ebay feedback |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Look's damn good .....Some nice new exhaust pipe would top it off.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
Thanks for the comments. I brushed the paint on. At first I used the cheap sponge type brushes but they fell apart quickly. I ended up using a cheap nylon 1" and 2" brush to finish it (I did not want to try to clean an expensive brush). The paint went on smooth and dried evenly. Time will tell on how it holds up. I did not put a top coat on it (Eastwood says it is not needed). As far as preping, I just scuffed the frame with 80-150 sandpaper to knock the dirt/surface rust down and wiped it down with laquer thinner. I was able to take the trailing arms to work to put them in a plastic media glovebox unit (the sandblast unit is to small). It cleaned them good enough to paint.
A while ago, I signed up to Eastwood's e-mail list and they send sale flyers about once a week. They have a 15% off sale on the rust encapsulator paint right now (a quart goes for $25.99 instead of $29.99) . I have read articles that some people like the Eastwood stuff better than POR-15. I have friends that have used both and they tend to like the Eastwood stuff better but they can get POR-15 locally so it ends up being a little cheaper. I got some of the paint on me and I was able to get it off without taking a layer of skin off (I have heard POR-15 is not so forgiving). Now I need to tear into the front end (I have had those parts around for years also).
Did the brush marks "level" out after you painted it? Thanks for the reply I think that I will use the Eastwood as well... Thank you Harold
my gas saver
thanks jjr, i seen the sale, how much do you think will get an entire frame done? i think i`m gonna try some.
In my opinion (IMO) everthing leveled out fine. Believe it or not, you are hard pressed not to think it was sprayed on IMO. I did not do a show quality prep job because my truck will never be a show quality truck. I think you will be happy with the Eastwood product.
I have used about 2/3 of a quart to do what you see (but I probably went alittle on the thick side). I would think it would take alittle over a quart to do the whole frame. I would buy a quart and see how far you can make it go. You can always buy more later.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB Second Owner 70 C-10 Second Owner 93 GMC C1500 Third Owner 99 C2500 Crew Cab Short Bed Last edited by JJR; 11-03-2004 at 11:08 PM. |
my gas saver
thanks again, keep her lookin good, later.
Its Magically Delicious
That looks great JJR... did you have trouble with the eastwood drying up before you could get it painted on ??
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
Looks nice..I was wondering what to use once I got my frame finished up..Thanks..
also I do like your jacking system..the really funny part is mine is the opposite. my box is on the tires...lol |
