Just like to part out trucks!!
4x4 adapter ???
Can a NP205 AT adapter be used on a 700R4 tranny, I got a guy that asked me about this? Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
It can if it came off a t350.
Support The Board |
Don't forget that the 700R4 will need a special output shaft.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements. |
Or a spacer that lets you use the origanal shaft the spacer kit is like $75 and the shaft $150 tha thaft will be 1in shorter then the spacer if space is an issue.
Earl 68 2500 4x4 GMC Burb |
Who sells the spacer kit? I've heard rumors, but never seen a place where I could buy it.
Advanced Adapters
What was I thinking??
Spacer
I put a 205 behind my 700r in my 83K5 If you go with the Spacer you will need 4 metric bolts or all thread and you have to grind about 1/8 off each shaft so they will not bind up and so you can seal the two up.
In the pic's you can see the spacer...
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
