Old 11-09-2004, 12:48 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Question Why would you need to relocate your front shock????
I have seen the parts, and read posts from people doing it. But why would you relocate the front shock? Got any pics?
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows"
http://67-72chevytrucks.com/vboard/s...d.php?t=200082
jugernot is offline   Reply With Quote
Old 11-09-2004, 01:22 AM   #2
gr8scott51
gr8scott51's Avatar
Wouldn't. The shock relocators I've seen (and used) are all for the rear.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 11-09-2004, 01:39 AM   #3
jugernot
Life, Be In It.....
jugernot's Avatar
I ask because I saw these:
http://cgi.ebay.com/ebaymotors/ws/eB...502885406&rd=1
Old 11-09-2004, 02:14 AM   #4
68327stepside
Here is a picture of the relocation. It is done to reposition the shock to the correct, >15 degree angle. Smoothes out the ride on slammed trucks a bit. Hope this helps.
USMC "Pray for peace, train for war"
(The Beast) 68SWB Stepside Original 325hp/327 3:73 Posi Lowered 3.5/4.5
68327stepside is offline   Reply With Quote
Old 11-09-2004, 02:15 AM   #5
jugernot
Life, Be In It.....
jugernot's Avatar
Thumbs up
Just the information I was looking for, good pic too. Thanks
Old 11-09-2004, 08:19 AM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
HERE is a good thread on the suspension board discussing this exact thing.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-09-2004, 01:26 PM   #7
gr8scott51
gr8scott51's Avatar
Interesting. Good info. This board always has the answer.
Old 11-10-2004, 12:25 AM   #8
68327stepside
I have a 2 1/2" set of drop spindles and 1" drop springs all from Classic Performance installed on the front of my 68 and before these relocators were installed the shock angle was at a 20 degree angle and after, they were back in specs at 10. Now at the same time I also rebuilt the entire front suspension joints, arms, and rods. Maybe that also had something to do with it. I was the rock that started the original post on these a month ago. The board memebers really helped me on this one. Thanks to all.
Old 11-10-2004, 12:46 AM   #9
jugernot
Life, Be In It.....
jugernot's Avatar
Thumbs up
Well, It sounds like I need to purchase some shock relocators, since I plan on putting air bags on my truck. Thanks all for the info.
Old 11-10-2004, 03:56 PM   #10
neonlarry
neonlarry's Avatar
Plus the fact that GM's front shock mount design was not very good. How many of you have replaced your front shocks and found that the mounting hole for the shock stud was ovaled out? Something with that much leverage on it should be attached on both sides.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 02-17-2005, 12:30 PM   #11
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Was following some links and found this old thread. What is the proper way to fix an ovaled out shock stud hole?
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 02-17-2005, 12:42 PM   #12
StingRay
StingRay's Avatar
Personally I use a washer on both sides of the frame and tack weld the outside washer to the frame. I have one done this way on my truck that has seen over 10 years of daily use and it's till perfect.
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
