Old 04-07-2002, 04:42 PM   #1
ebfabman
Post ID this rear end......
Any value, Whats it worth?
Anybody need it? It was good when the truck was running, should still be in good working order.
ebfabman is offline   Reply With Quote
Old 04-07-2002, 04:52 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Post
Corprate with coils.
never seen one with coils, but I have never looked at a 3/4 ton with coils either.
Can't say what it is worth.
'69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man
I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it.
FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite.
If you need a pic posted, E-mail me at longhornmail@yahoo.com
Andy, in Columbus Ohio
Old 04-07-2002, 05:54 PM   #3
Fast68Chevy
Fast68Chevy's Avatar
Post
H052 5200lb axle is worth its weight as a boat anchor unless its got a NoSpin in it, theyre wayyyyy too common, as they were standard equipment under all these trucks 47-72, and are very problematic in that the seals like to leak all oil out and the bearigns liek to chew up and therefore leaves a ton of slop in the pinion gear to ring gear teeth contact -as many here have found out the hard way about-
H052 with coils is wayyyyyy more common than same with leaves, as coilsd were standard under all except longhorn and 4x4, in which both case have no available option of coils type suspension
good luck
Randy- Lincoln, IL
r68c30@hotmail.com
71 C-10, trying to assemble....sigh..
parting out 5.0LTPI '81 cutlass supreme brougham
*Paint is overrated
© RSS Enterprises 2000
[This message has been edited by Fast68Chevy (edited April 07, 2002).]
Fast68Chevy is offline   Reply With Quote
Old 04-07-2002, 06:24 PM   #4
ebfabman
Post
OK then, my next post will be;
Boat anchor for sale. Can also be used as a Corprate HO502 5200 lb axle, may be problematic. Best used when two people are available.......
Old 04-07-2002, 06:26 PM   #5
69 longhorn
Post
LMAO....it is pretty heavy! might make the boat lean too.......69 longhorn.
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 04-07-2002, 06:47 PM   #6
Rod
Post
Someone may want to use the gears if they are the better highway gear of 4:10 ratio. They have been asked for on this board before.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 04-07-2002, 06:58 PM   #7
ebfabman
Post
I'll check on the gear ratio. Any idea on what they're worth assuming they are 4.10's in good shape?
