Old 11-11-2004, 12:08 AM   #1
jakeslim
Premium Level Member
jakeslim's Avatar
Need a pic of power steering pump w/brackets installed
I am missing a bracket for my power steering pump. I have the pump, its cradled in a big bracket, but i'm sure there is another bracket I'm missing(?). I posted on here looking for one, but no one was sure what I needed. I figure if I can get a pic, then I can ask for the right part.
thanks,
jakeslim
jakeslim is offline   Reply With Quote
Old 11-11-2004, 12:35 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
What year? what engine? What size pump? What side is the alt on?
Old 11-11-2004, 12:52 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Here's a shot of the bracket on my 69, the pump bracket bolts to this one.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 11-11-2004, 12:54 AM   #4
Longhorn Man
That is the small block with the short water pump...as stock (alt on drivers side)
Old 11-11-2004, 12:58 AM   #5
jakeslim
jakeslim's Avatar
Yep, thats what i got...short water pump , alt on drivers side, 350...and thats the bracket I need. I will reference that pic in my quest. Is that bolted on to your motor mount?
thanks for the help,
jakeslim
Old 11-11-2004, 01:02 AM   #6
Longhorn Man
Yup, bols to the motor mount, and that is where they commonly break too.
Old 11-11-2004, 08:20 PM   #7
Wootdog
Wootdog's Avatar
Where is bolts.
I have a small block. No pics. My power steering pump bolts on the left side. It actually has a bolt with a standoff and washers. Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
Old 11-11-2004, 08:42 PM   #8
Sweet72
Sweet72's Avatar
Nice looking engine Fred T. There should be a cast iron cradle type bracket that mounts in front of the sheet metal bracket in Fred T's pic.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
