It followed me home?
will these rims work?
On my '73 3/4 ton? I dont have any info on these wheels but was hoping someone here might know if they will work. Thanks
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Well they look like the ones on my 2500HD 2002. If they are the same I believe it is GMC paul that is putting them on his garden truck. He was having small issues with the centercaps, do a search for the "garden truck"
2008 Buick Enclave(wifes new non wrecked) 1996 Jeep Cherokee 2002 2500HD 6.0L (traded) 1998 Jeep Grand Cherokee(wifes/wrecked) 1977 DJ5 postal jeep(mmm lots of fun) 1988 Toyota 2wd p/u(DD, blewup 199,000) 1991 Toyota 2ed p/u (sry just cant break these things) 1997 XR70 Honda 1991 Z50(FOR SALE) 1972 Z50 Honda 1970 SWB 350/knucklebuster "The adventure begins and I am confident that there will be no end". |
that is Wes that has the Garden Truck, not GMCPaul.
The only issue I could see running them is not being able to use the stock center caps up front to cover the lockouts, I think those rims look good...oh, and they are made for GM by Alcoa, so they are good quality.
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
Do the 8 luggers use hub centric like the 6 luggers? late model 6 lug wheels won't fit over my hubs or over the little round peice on the rear drums.
1985 Scottsdale Shortbed 4x4 Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch. 2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle. |
please don't break
I've been wondering the same thing, wanting to convert my k10 over to 1 ton axles....and 8lug
#6 | |
All GM 8 lug wheels (all years, not including dually wheels) have the same bolt pattern, center hole diameter, and offset. Only Ford went to the metric bolt circle.
Tim |
Mudslides 'r my specialty
I saw a yellow 67-72 in a magazine with those, so I assume they do work.
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.) http://www.cardomain.com/memberpage/500339 |
Land Beast
The only thing is the back spacing might be to shallow. but then again those h2 rims fits are style trucks.
90' GMC 1 Ton Suburban |
Very odd, yet timely
****! I had the same question today at work. The reply I got was yes they would fit fine. There are aftermarket center caps if you don't want to dremel your manual hubs out of prison.
My question is this- With a 4" lift and 35x12.5 BFG KO's on these new 8" rims- how much tire is going to stick out past the wheel well?
72 GMC 3/4 ton 4wd- Col. Mustard 94 Kenworth/MTM concrete mixer |
#10 | |
I dont think any would stick out.
I assume their 16" tall wheels? So they should clear the steering arm, but is it possible with a 12.5" wide tires and a good deal of BSing they could rub the springs? You might wanna put some spacers on the back too otherwise their gonna be tucked in tight and might rub something with a 12.5" tire.
please don't break
yea today i was at the NHRA drags at pamona and i talked to a rep from American racing wheels and he said exactly that......ford had changed a few times since the late 80's early 90's but gm is still the same, new 8 lug chevy wheels will fit older chevys.....
#13 | |
20' Daredevil (Ret)
![]() Join Date: May 2003
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
If you are talking about the wheels in the picture in the first post in this thread, then yes, they are 16 X 6 1/2 inches.
Tim |
#15 |
Oh no. That's a wrench in the plan. BFG recomends at least a 8" wide rim with 12.5 wide tires. Any ideas?
#16 |
H2 rims...but they are 17 x 8.5 , there is a set on ebay selling for $150 right now.
#17 | |
Windy Corner of a Dirty Street
You will also need a set of 36 of these lug nuts as the late model metric nuts will not fit an older truck. (36 X $1.40= $50.40) ouch!
Current vehicle collection: 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
#18 | |
20' Daredevil (Ret)
#19 | |
I would like to say that I order 2 extra nuts to have around but the truth is I can’t spell very well. I mean type, I mean subtract…..or is it add. Ah, you know what I mean. ![]()
#20 |
graphic designer
i second the warning to watch the backspacing. i bought the nice 18" wheels in my avitar with the assurance they would fit. they do, but i cant turn all the way to the right. about half way there, the tires hit the drag link where it joins the steering arm HARD. enough that if you werent thinking, you might end up ripping the steering box off the frame! it hits REALLY hard. and the rears rub about an inch of the inner fender/bed area, but only if you get it twisted up so the tires are tucking. the wheels are 18x9 with about 5 inch BS. if you can find a set fo compareable wheels, do some trial and error looking without the tire to see if they might rub anything when steering.
good luck, they are nice looking wheels! |
#21 | |
YAAAYYY!!! After much searching I have finally found the specs for those nuts! Thank You! Thank You!
~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ '68 GMC Sub 4X4 new project ![]() '69 Pontiac GTO 20 year project ![]() ![]() Never hold your farts in. They travel up your spine, into your brain, and that's where you get sh*tty ideas from. |
#22 |
One more time…..Stock 8 lug GM wheels such, as the one’s in the picture at the beginning of this thread, (RPO code: PYO on 1999 to current GM trucks) have had the same backspacing since the late 50’s or early 60’s.
Where you run into problems is when adding aftermarket wheels such as 724wdcopper’s 18” wheels. I run 285/75x16 BFG’s on my Silverado HD with these same PYO wheels with no problem.
#23 |
wait which one is it?
#24 | |
#25 |
yeah, which lug nuts do I buy so I acn used late model caps?
Here's my girl, those are '78 3/4 ton axles.
