![]() Join Date: Feb 2000
carb linkage
My 69 K20 has the hard linkage to the carb. I need the linkage that connects to the carb to be about 3" longer.
The rod is right about 10" long and 1/4" diameter but it is a fine thread and I haven't found anything like it yet. Needs to be about 13" or so long. I see a couple options assuming I can't find a connector and some all-thread to lengthen it: 1. Cut it and weld in a piece of rod in the middle to keep the end thread correct. 2. Tap the piece it goes into to 5/16" and use a piece of 5/16" all thread. Let's here some suggestions or other recommendations. As always cheaper better but don't want to end up looking like a hack job. ![]()
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
i have a longer rod that came off of brother's 70 lwb 350 truck. It is 1/4 etc.. If you are interested shipping will get it to your house. Harold
Cantankerous Geezer
Solution 1. Use your eyeballs and place a line in space between the carb linkage and your right hand in the cab. Drill a hole along that line. Then take a piece of baling wire connected to the carb linkage, through the firewall and dash so you can pull it with your right hand. Instant Throttle, and it's cheap!
![]() Solution 2. Replace the linkage with a cable. Solution 3. Weld a piece in the middle of the linkage. Solution 4. Take the truck back to the painter and tell him he didn't finish. Just be ready to streak next fall. :p
Fred There is no such thing as too much cam...just not enough engine. ![]() |
#4 | |
Still drivin' a Rat Rod
![]() I would send Harold a few bucks ![]()
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
Harold, I will pm you - thanks.
Fabricate till you "puke"
A couple guys posted pics a while back.....use all thread , with rod ends & slip a pc of tubing over the threaded rod to "clean it up". It will be a very slick looking & funtional pc (fairly cheap too)
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
The rods are easy to make using 1/4" rod, threading the one end and drilling a cotter pin hole in the other after bending it.
The problem is that the fitting is not national fine thread but a different thread count so what I have done is rethread the fitting with a 1/4-28 tap. Jim |
Why not weld a new arm to your firewall bracket that sticks out the 3 inches? Paint it and I think it would not be noticed,but that's just me
Got Light Emitting Diode?
i cut mine and welded a chunk in. but i am thinking about getting a peice of round stock and threading each end and threading on the ball joint swivel thing-ma-bobbers. (i think thats what they are called
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#10 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I get them at Summit for like 4 bucks each. They make real good throttle linkages when coupled with a threaded length of 1/4 rod.
COMING SOON...
I rednecked my linkage with a length of coat hanger, slipped a bit of new brake line over it, & tied off the ends. A good "long-term temporary" solution.
#12 | |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
I used a throttle rod for a 1967 BBC Camaro (available from Classic Industries). It fits perfectly.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
