Old 11-22-2004, 02:34 PM   #1
zooza
Cool 30 ugh 5 mods?
Anyone got any good suggestions for me to enhance the 305. its in the garage awaiting gaskets so i figure while im in there i will add a high volume oil pump, quality new timing set edelbrock performer rpm and edelbrock carb.
any suggestions, hints etc ? trans is a turbo 350 , I'll be towing a medium sized bass boat and basically cruising. any suggestions accepted with hearty thanks! what cam? what color should i paint the block its got orange heads and a blue or black block neat huh?
zooza is offline   Reply With Quote
Old 11-22-2004, 02:41 PM   #2
jhow66
jhow66's Avatar
Check to make sure it is a 305. Orange heads don't soud like 305 heads.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-22-2004, 02:52 PM   #3
zooza
the blockis definately 305 the heads? you know how po sometimes mix and match stuff.
Old 11-22-2004, 03:23 PM   #4
dylan1970
dylan1970's Avatar
A few years ago my brother helped me freshin up my 305 (that was in my cutlass) and we put a cam from a '74 400 block in it. It really made a difference from the stock motor. I don't know alot about engine build ups and what is compatable but if you talk to some other people and ask their opinions I'm sure you will get a good running engine when all is put back together.. Good luck!
dylan1970 is offline   Reply With Quote
Old 11-22-2004, 06:59 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You must ensure those are 305 heads. Pretty much anything else will not work, and cost quite a bit when you tryto make it work.
Don't waste time/money with a high volume pump. A quality stock unit is all you need, and high volum/high pressure pumps rob power.
Just put a performer intake on, a 600 CFM carb of your liking, HEI, some small tube headers and small dual exhaust, and make sure it is tuned fine.
You won't win any races, but it'll do what you need it to do.
Old 11-22-2004, 07:05 PM   #6
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I prefer Ford Red on my engines,cause I don't like the Chevy orange,but hte GM blue is good too,depends on what you like I guess.
And longhornman about covered it for ya
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-22-2004, 07:25 PM   #7
crazy longhorn
Fabricate till you "puke"
I have a 305 in my S10, the same one that ran in my 1 ton flatbed(78 & ugly), & the kids 89 ford ranger. the 305 is a little underpowered in a full sized truck.....but will work in a "pinch". I have one of my favorite oiling systems for street use.....a 6 Q truck pan, with a melling Z28 replacement pump. The top was done(fresh grind & a set of Z28 springs). the old tired chev runs a Crane fireball H290 cam(.454 lift, 216 dur @ .050), & idles fairly smooth. it runs pretty good in that small truck, & not too bad in a bigger truck(provided the gears are low enough). crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-22-2004, 10:21 PM   #8
zooza
thanks for the info
