Old 11-23-2004, 09:19 PM   #1
Bleach
this guy
Bleach's Avatar
Will a 69 body bolt onto a 74 frame?
I have a good line on a 74 rolling chassis that already has an engine on it and is ready to go. Will my 69 body bolt onto it with no problems? I realize this may be wishful thinking, not sure though.
Also, I am still in need of the metal bed floor to fit my 69. If I took a LWB bed floor, could I cut off some of the excess to fit my SWB. I know that the bed floors from 67-88 are pretty much interchangeable with the exception of a few holes, but I'd love to know if this will work.
Thanks all,
Tom
Duct tape is like The Force. It has a light side, a dark side, and it holds the universe together.
Bleach is offline   Reply With Quote
Old 11-23-2004, 09:29 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
...Will my 69 body bolt onto it with no problems?
The short answer...
no.
If you wanted to do a body lift, (kinda dumb on a 2 wheel drive) and modify the wheel base a bit, you could make it work, but your better off just pulling the engine off of it, and pulling the front cross member to easily swap the 5 lug/disc brakes.
Old 11-24-2004, 03:47 AM   #3
Bleach
this guy
Bleach's Avatar
No matter that it is 4WD?
Old 11-24-2004, 05:13 AM   #4
krue
Designated A-hole!
krue's Avatar
4wd you can do it. Talk to Mudder 67 he has the best example I have seen.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-24-2004, 10:57 AM   #5
Mudder
Mudder's Avatar
Yep it'll work with a 4x4.
Mudder is offline   Reply With Quote
Old 11-24-2004, 01:42 PM   #6
GMC AMI
GMC AMI's Avatar
There must be rolling 4x4 frames around. Do a search first unless you are in a hurry.
Too bad I am so far north for I have a couple, one 1/2 one 3/4. Good bodies are harder to find IMO.
1968 Chevy 4x4 307 4 speed
GMC AMI is offline   Reply With Quote
Old 11-24-2004, 01:47 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
I wouldn't do it. You'll be reviled by the 73-87 guys and ostracized by the 67-72 crowd...the proverbial bastard child. Of course you'll have Mudder to pal around with... J/K
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-24-2004, 02:36 PM   #8
Mudder
Mudder's Avatar
Lmao................
Old 11-24-2004, 07:03 PM   #9
Bleach
this guy
Bleach's Avatar
Ok, so I really don't have a definitive answer yet. Mudder 67 has had success with it and is obviously a pro.......but throw me some bones here folks! Also, I never did here if I could cut down the long bed floor with relative ease to fit a short bed.
Old 11-24-2004, 08:01 PM   #10
c-1072
Not easy at all
Unless you are ready to do a bunch of fabricating dont try it , you will have to fab up all the body mounts and raise the body well above the frame .
c-1072 is offline   Reply With Quote
Old 11-24-2004, 08:11 PM   #11
Randy70C-10
Randy70C-10's Avatar
Hmmmmmm, I knew someone than put a 67 on a newer chassis, wish I could remember who it was. For some reason, the name should be very familiar to me.
Randy70C-10 is offline   Reply With Quote
Old 11-24-2004, 07:58 PM   #12
Mudder
Mudder's Avatar
Bleach check out this thread. Its right here near the top.
http://67-72chevytrucks.com/vboard/s....php3?t=128933
Old 11-24-2004, 08:14 PM   #13
Mudder
Mudder's Avatar
Using the old body mounts, you attach them to the outside of the frame in almost the same location as the newer ones were on the inside. I actually used some of the same holes that were there. I have less than 3 inches of body lift on my bed. If i would have used a high hump I could have gotten away with no lift under the bed/2 under the front clip and about 2 under the front cab mounts. Very few people realize that my truck sits on a newer frame. When you put the cab on the frame you have to be very careful that you can get the distributor in and out.
Now cutting a bed is a different story........
Old 11-24-2004, 08:16 PM   #14
Mudder
Mudder's Avatar
Thats a clean truck there Randy........
Old 11-24-2004, 08:43 PM   #15
Randy70C-10
Yeah, I heard that it gets around too.
Old 11-24-2004, 09:08 PM   #16
RANDY COX
RANDY COX's Avatar
BLEACH where exactly are you located in southwest va,I'm in c-burg.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 11-24-2004, 10:52 PM   #17
Bleach
this guy
Bleach's Avatar
I'm in Bristol........a tad more SW than you, right off ye old I-81.
Old 11-24-2004, 11:07 PM   #18
RANDY COX
RANDY COX's Avatar
Cool,good to have another board member close by,
1964 BBC 402 4x4
