11-25-2004, 01:30 AM | #1 |
Under construction!
Front suspension components!
Brand-new 1987 16-gallon replacement fuel tanks (Purchased from Classic Industries). Powdercoated sparkle silver. $175 shipped for both.
* These should fit all 73-87' SWB trucks. I am told the only difference between 86' and 87' tanks is a sump at the bottom. Fuel tank brackets (4). Powdercoated sparkle silver. $125 shipped OBO. Plastic fuel tank covers lined w/ Line-X inside and out. $75 shipped OBO. GM sending units, fuel pumps, and strainers. Installed but never operated. $350 shipped OBO for both sides! GM frame mounted fuel switch valve. Installed but never operated. *Make an offer because I don't remember how much I paid for it!* $500 takes everything shipped to your door. *Updated 12/01*
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 12-01-2004 at 02:53 PM. |
11-25-2004, 10:57 AM | #2 |
Active Member
Couple questions:
-Are all the suspension parts (the first batch, A-arms, ball joints, etc.) sparkle-coated, or just some? -Any idea of shipping to 30076? Thanks...and Happy Thanksgiving! Brian |
11-25-2004, 12:06 PM | #3 | |
Under construction!
I had the control arms, cross shafts, and washers powdercoated before assembling everything. They look great! Shipping won't be cheap but I'm asking $250 shipped to your door. BTW, I will post pictures of everything I have for sale Tuesday morning.
2001 Silverado bagged on 22's. *Sold* |
11-25-2004, 08:52 PM | #4 |
Garage Queen Material
i want the a arms and expecially the swaybar
11-25-2004, 09:41 PM | #5 | |
Under construction!
Shoot me a PM if your serious.
11-25-2004, 11:07 PM | #6 |
Under construction!
*Edit*
2001 Silverado bagged on 22's. *Sold* Last edited by BaggedC10; 12-01-2004 at 01:28 AM. |
11-28-2004, 12:10 AM | #7 | |
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
11-25-2004, 11:26 PM | #8 | |
i just saw how that came out. i mean i WANT them. not i can AFFORD them or have the money to spend on them |
11-25-2004, 11:27 PM | #9 |
Under construction!
No problem.
BTW, I'm flexible on these prices, so buy all this stuff.....someone!
11-25-2004, 11:51 PM | #10 |
thats the exact anti-sway bar i want. but after ordering my rearend parts last night, i've got exactly $150.67 in my checking account and only a little bit of cash
11-26-2004, 01:33 AM | #11 |
Under construction!
Just to clarify.....
I'm selling the complete ART Cool-Ride kit, minus shock absorbers and steering stops for $175! This includes two 90* PTC fittings and hardware. The kit retails through ART for $524 + tax/shipping.
11-26-2004, 01:42 PM | #12 |
Active Member
I'm interested, esp in seeing the pix.
I PM'd you. Brian |
11-26-2004, 02:16 PM | #13 |
Under construction!
Here is the color.
Sorry, about the small pictures. The metallic or sparkle is only noticeable when in direct sunlight.
11-28-2004, 02:28 AM | #14 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
11-28-2004, 08:25 PM | #15 |
Active Member
I hate to say it, but the xmas budget just doesn't allow right now. I've tried to maneuver around it, and maybe I will eventually , but I have to pass for now.
Brian |
11-27-2004, 01:01 PM | #16 |
Under construction!
TTT
11-27-2004, 07:28 PM | #17 |
Hmm...bags are getting mighty tempting...
11-27-2004, 08:56 PM | #18 | |
Under construction!
Especially, for $175. I'll even install the front kit if you drive up here, Tim.
11-28-2004, 10:01 PM | #19 |
Under construction!
No problem, Brian.
11-28-2004, 10:34 PM | #20 |
what exactly else would i need to buy to make the ART front kit work??
how much would a compressor and tank be? |
11-29-2004, 12:20 AM | #21 | |
Under construction!
You could run the front of a schrader valve until you have money for a compressor system. I would recommend a 5-gallon air tank, Viar 400 compressor, (4) SMC 1/2" valves, and of course 1/2" air line. This would be an awesome setup to add-on to if/when you bag' the back. It also depends on how quick you want your system to be. The only thing you will NEED is shock absorbers. ART supplies Monroe shock absorbers standard but I don't have those anymore.
11-29-2004, 12:31 AM | #22 |
so, if i were to say, buy that from you. what would i need to buy/do to get it all installed??
what if i just wanted to change the ride height when i was at home with a compressor i have in my garage?? is that what the schrader valve does?? |
11-29-2004, 01:07 AM | #23 | |
Under construction!
This would give you independent control of the air springs. You could run the air line outboard of the frame rail, along the cab mount/floor pan support, and to the rocker panel (Picture it routed in an "L" shape w/ the top of the "L" being the front X-member). Secure the air line to the frame 8-10" behind the front X-member and to the cab floor support using (2) insulated clamps and you would be set! BTW, check out the following link. http://207.44.196.117/vboard/showthread.php3?t=129463
11-29-2004, 01:09 AM | #24 | |
Under construction!
Yes, you could inflate the bags at home or at a gas station.
11-29-2004, 01:12 AM | #25 |
so i would need an air tank for it?
