Old 11-25-2004, 01:38 AM   #1
chevybill
chevybill's Avatar
Talking How to tell if steering box is good?
Hey guys, happy turkey day to all
How can I tell if my steering box needs replacing? I have the steering disconnected from the box, as I disassemble for my resto/mod project.
I can move the splined spindle about 25% of one turn without encountering any resistance. Before disassembly, I could wiggle the steering wheel just a little and the wheels would wiggle with the steering wheel. When driving, I had some slack in the steering, about 25% of a steering wheel turn.
Will a later 73 and up steering box fit? It presently is manual steering and I plan on staying with manual steering.
Is it cheaper to replace than rebuild?
Thanks for your replies.
My engine guy is trying to get me to go with a 350 automatic tranny and a rear gear of 3.42 or numerically lower (higher speed rear end). This setup will be much cheaper than a 5 speed, so I am going to have to think about this.
Any thought appreciated.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 11-25-2004, 01:57 AM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Whatcha got in the diff now? 3:73 or lower go with a 700R4. Has .74 overdrive. Works real well. Going the other way with taller gears in the back is definately a way to go if you are not planning on towing or hauling any heavier loads. I like having the option of dropping it in 3rd with my 700r4 and still having a 1:1 on my tranny with 3:73's in the back.
No comment on the other questions... No experiance with it.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 11-25-2004, 02:08 AM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
The later box will fit,and work just fine.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 11-25-2004, 02:32 AM   #4
chickenwing
How bout for a C20?
Old 11-25-2004, 05:12 AM   #5
jimfulco
As long as it's not from a 4WD.
jimfulco is offline   Reply With Quote
Old 11-25-2004, 06:08 AM   #6
dwaite72lnghrn
Have you ever adjusted the steering box you have now? If it hasn't ever been adjusted you should be able to take the slack out by adjustment.
Loosen the locking nut on the top of the box then turn in the adjusting screw on the top, Move the shaft back and forth till the slack is out then tighten the locking nut.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-25-2004, 09:33 AM   #7
spencra
This, is my BOOMSTICK!
spencra's Avatar
You should be able to get a straight answer from a good parts dealer (I recommend NAPA or even a chevy dealer). They will get the information that they need from you and should be able to answer your question or at least steer you (no pun intended, really) in the right direction as to what you will need or can use.
Larry
Got rid of my projects for now.
1980 Jeep CJ7
1998 Nissan Sentra (my car)
2001 Toyota Sienna (wife's, of course)
spencra is offline   Reply With Quote
Old 11-25-2004, 10:42 AM   #8
chevybill
chevybill's Avatar
thanks for the replies, everybody.
since the box has never been adjusted, i will try that first.
as a side note to any one wanting to keep manual steering,
summit can get these boxes new and they are about 300 dollars.
Old 11-25-2004, 01:32 PM   #9
Brainchild
Brainchild's Avatar
Guess I'm getting old,the first mod I'm concidering on my 49 is power steering
Rusty Member #13872
71 GMC LWB
49 Chevy
85 Chevy G20
