Booster Rod
Can you adjust the rod distance from the booster without having to disconnect the master cylinder?
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Are you asking about the one under dash?
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Yes I am. Also is there a way to adjust the one on the booster where the master cylinder connects?
its all about the +6 inches
if you are talking power brakes, i think the one under the master cylinder is the only adjustment. You don't need to disconnect the lines, just the two 9/16 nuts and pull the master cylinder away. The lines will give you enough room.
Your brake pedal should touch the rubber bumper under dash and have a little free motion when you go to apply the brakes.
Brakes Update:
I replaced the master cylinder. I bench bled it. I didnt have time to bleed the entire system but there is some improvement. I am going to bleed the system tomorrow and I will let you guys know what happens. Thanks
